SOS Technical Glossary
Re: SOS Technical Glossary
Postby Hugh Robjohns » Sun Feb 04, 2018 5:03 pm
Yes... I did wonder about that as I typed it and was going to consult with my colleagues about it tomorrow. But what the heck, let's just go with 'flexible'! I've updated the entry.
Postby wireman » Tue Feb 06, 2018 9:53 pm
John Willett wrote:A Gooseneck (sometimes calles swan neck) is always flexible - that's why it's called a goose neck.
I thought this as well but I did a quick check for exceptions and came up with this microphone which is described as having a fixed-placement gooseneck.
Looking further, I see that this does not mean what I thought it did at the time.
wireman
Postby John Willett » Wed Feb 07, 2018 4:17 pm
This microphone *is* flexible - it just has a solid bit in the middle, but it's flexible at both ends. So can really be called a gooseneck.
If it was fixed angles, like the AKG VR1, then it would not be a gooseneck.
John Willett
Postby Eddy Deegan » Tue Nov 06, 2018 2:25 am
That's a comprehensive glossary Hugh :)
While browsing it I noted the lack of an entry for Overtone. At first I thought it was just another word for Harmonic but something in the back of my head tickled and I googled it a bit and found a definition of Overtone is defined as any frequency having a larger value than the fundamental frequency of the system. When an overtone is combined with the fundamental frequency, it is known as a partial. A harmonic is such a partial having an integer multiplication of the fundamental.
Overtones featured in my early piano education but I'd lost the definition over the years - basically, they are the mess from which harmonics can be picked. Or something!
(May be too trivial for the glossary but I figured I'd mention it)
Some of my works.
Postby Hugh Robjohns » Tue Nov 06, 2018 11:34 am
Thanks Eddy, I'll add that one in. EDIT: Done!
I remember getting horribly confused way back with the different numbers of overtones and harmonics...
Postby Folderol » Tue Nov 06, 2018 5:41 pm
Thanks for that Eddy. It greatly clarifies some aspects of my synth of choice - especially as the original designer is not a native English speaker!
Yes. I am that Linux nut.
Postby ef37a » Thu Nov 22, 2018 5:20 pm
Hugh Robjohns wrote:Thanks Eddy, I'll add that one in. EDIT: Done!
I dimly remember being told that 2kHz is the FIRST Overtone of 1kHz but the SECOND Harmonic?
Postby Hugh Robjohns » Thu Nov 22, 2018 5:45 pm
Quite so! :D
Postby wireman » Thu Nov 22, 2018 8:11 pm
Since I just sent my old cassette tape deck (AIWA AD-F660) away to see if it can be repaired I realise the glossary is missing some tape-related definitions:
  • Wow
  • Flutter
  • Dropout (tape)
Also for the Dolby entry describing noise reduction and surround technologies there was also Dolby HX which I think just optimised the use of bias on recording for high signal levels.
wireman
Postby Hugh Robjohns » Thu Nov 22, 2018 9:07 pm
wireman wrote:I realise the glossary is missing some tape-related definitions:
Good call. I'll add those tomorrow.
Yes, as I recall, it reduced the bias level when there was strong HF content in the audio signal to avoid unnecessary overbiasing. I'll check the detail and add it to the glossary. Thanks.
Postby Hugh Robjohns » Fri Nov 23, 2018 12:37 pm
All added -- thanks for the suggestions. Keep them coming!
