Folderol wrote:ef37a wrote:Hacksaw a splicing block Hugh?
I think I would rather give a local engineer a decent drink and get it milled!
Indeed :o
My Bib one has only 60 and 90ish deg, and the slits are very fine - just enough for a razor blade. Rather than shaped edges to hold the tape it has two clips with cork pads.
Personally I preferred that, as an accidental {very slight} movement of tape or block doesn't move the tape just after you've cut it!
I always hated the Bib block as it did not hold the tape properly at the point you cut it and the tape sometimes curled up and you could not cut as accurately.
Personally I used to put two piesec of tape in the block - one on top of the other with both splicing pints on top of each other. The cut would then cut both sides of the cut identically and make for a much cleaner join.
With the EMIblock (and the like) the cuts were fine when new, but the slot tended to widen with use so each cut could be slightly different - which is why I liked to cut two at once so the join was perfect.
I remember seeing one block that had been screwed to the ytape recorder at LBC London that had actually been cut all the way through with use and the two halves would swivel separately - and more - the reporsers had actually cut a slot all the way through the recorder's top plate with use. :o
THough, personally, in the latter days, I moved over to the
CAT tape splicer which was much better. :thumbup:
I still have it.
Canford Audio still sell single-sided razor blades and Chinagraph pencils - but nit the blocks, it seems.
