Not Toys, but Tools
Post your own hardware/software reviews.
Not Toys, but Tools
Postby Mike Stranks » Mon Dec 10, 2018 7:42 pm
Let's be honest... many of us struggle with soldering and either make a poor fist of it, burn ourselves on the iron, can't get the solder to 'take' or experience some other combination of catastrophes. And some won't even contemplate soldering... if they can't buy the lead they need then a weird and wonderful combination of adapters is brought into play. Guilty m'lud... :oops:
Over the years I've tried all sorts of 'helps' to hold the work secure as that seems to be one of the secrets to getting a good joint quickly and cleanly. A couple of years ago I got one of those 'helping hands' gizmos which was an improvement, but still didn't always either hold the work securely enough or get it at just the right angle for easy access with the iron.
A few months ago I came across the Stanley Multi Angle Hobby Vice - yours for about £15-£20.
The huge advantage is not only can the work be held very securely, but its angle can be adjusted so offering up the solder and the iron becomes very simple and straightforward.
Soldering is no longer a 'will it/won't it' work exercise, but has come a simple task which I can achieve quickly with no stress, no burnt fingers and connectors that work first time - and stay working!
Recommended!
Re: Not Toys, but Tools
Postby Hugh Robjohns » Mon Dec 10, 2018 7:55 pm
Not seen that before. Clever. Thanks for sharing that.
Postby MOF » Mon Dec 10, 2018 10:25 pm
I’ve used a two handed crocodile clip device from Maplins (RIP) to do this. Wouldn’t be much use for the bigger, heavier connectors though.
MOF
Postby blinddrew » Mon Dec 10, 2018 11:11 pm
How big is it please Mike? It's hard to tell from the pic. Either dimensions or weight - i'm a little bit worried it would be too heavy for my collapsible table.
Edit - ignore me, found it now. 1.5kg if anyone is wondering.
Postby Wonks » Mon Dec 10, 2018 11:45 pm
Be careful. The wife may find it quite useful for retribution if she finds yet another guitar that you've apparently had for ages...
Postby Mike Stranks » Mon Dec 10, 2018 11:47 pm
blinddrew wrote:How big is it please Mike? It's hard to tell from the pic. Either dimensions or weight - i'm a little bit worried it would be too heavy for my collapsible table.
I was using it this afternoon on the 'flap' of a kitchen table and all was well.
In fact I had one of these:
fastened to the same flap.
I've seen some complaints from people who tried to use it as a full-on woodworking vice. I don't think the ball joint would take the strain of (say) planing oak, but for 'our' type of stuff it seems fine.
Postby Mike Stranks » Mon Dec 10, 2018 11:51 pm
MOF wrote:I’ve used a two handed crocodile clip device from Maplins (RIP) to do this. Wouldn’t be much use for the bigger, heavier connectors though.
That was the problem I had. The mini croc-clips simply weren't 'beefy' enough to hold an XLR shell firm when seeking to thread/position wire cores.
Postby BJG145 » Tue Dec 11, 2018 12:12 am
I picked up one of the helping-hands type things recently, but the main problem I had was eyesight. :tongue: Electronics soldering seems ridiculously small. This looks useful for more robust work, but for me it would be like doing embroidery with boxing gloves.
Postby Sam Spoons » Tue Dec 11, 2018 12:35 am
I use my cheapo Behringer cable tester for holding plugs for soldering, it's not perfect but maybe I should make a dummy socket board for the job. OTOH, lamping the Berry thing into that vice would work perfectly (TBF the Berry cable tester actually does work very well for it's intended purpose too).
Postby Mike Stranks » Tue Dec 11, 2018 12:06 pm
BJG145 wrote:I picked up one of the helping-hands type things recently, but the main problem I had was eyesight. :tongue: Electronics soldering seems ridiculously small. This looks useful for more robust work, but for me it would be like doing embroidery with boxing gloves.
Don't quite get this.
The vice isn't that big... jaws probably 75mm long... and it's about holding the work very steady so that (in my case) now slightly trembly hands can bring joint, solder and iron together more easily.
I agree about eyesight... That's why I bought the LED-illuminated magnifier at the same time. Using the vice and magnifier together has made soldering life a whole lot easier.
Postby Mike Stranks » Tue Dec 11, 2018 12:08 pm
Sam Spoons wrote:I use my cheapo Behringer cable tester for holding plugs for soldering, it's not perfect but maybe I should make a dummy socket board for the job. OTOH, lamping the Berry thing into that vice would work perfectly (TBF the Berry cable tester actually does work very well for it's intended purpose too).
That's a good idea... but doesn't the cable tester act as a heat sink and isn't there a risk of damaging components if you're a bit slow with the soldering and heat gets transferred into the tester? Jus' wonderin'
... and I agree about the tester itself. Really useful gizmo and the tone generator is also great.
Postby Hugh Robjohns » Tue Dec 11, 2018 12:51 pm
Mike Stranks wrote:That's a good idea... but doesn't the cable tester act as a heat sink and isn't there a risk of damaging components if you're a bit slow with the soldering and heat gets transferred into the tester? Jus' wonderin'
Yes, it does act as a heatsink, but you'd see damage to the plug you're working on before the one in the tester suffers.
I tend to use either a StudioSpares universal cable tester, or an ART DTI box to hold plugs steady while I'm soldering cables. Never had an issue with it. The worst that could happen is that you'd melt the solder on the cable tester plug and an internal wire could ping off (that wouldn't be an issue if the internal wiring is via a PCB of course)... but you'd have to keep the iron on so long to do that you'd be guaranteed to wreck the plug you're trying to work on anyway!
Postby Sam Spoons » Tue Dec 11, 2018 1:22 pm
Wot e sed :thumbup:
Postby Sam Spoons » Tue Dec 11, 2018 1:23 pm
But one of those vices would be just the thing to hold the cable tester steady ;)
Postby Watchmaker » Tue Dec 11, 2018 3:33 pm
nice! I usually kludge together an assortment of pliers to hold tricky bits more or less in place whilst inhaling solder rosin, squinting feverishly and hoping I don't get a cold solder.
The ball joint knuckle on this is just the thing! Amazon, here I come...
Watchmaker
