Wonks wrote:Fixed link (for long URLs you need to manually put the [ url ] boxes around the link or it doesn't work).
Thanks Wonks - I should have checked the link.
zenguitar wrote:In a lot of guitars with pre-amps the power is 'switched on' when the jack plug is inserted. The guitar has a TRS socket with the power circuit connected to the ring connection. But the 'trick' is that the guitarist uses a TS jack plug so the ring connection is connected to ground which completes the circuit.
The AG stomp takes advantage of this connection to inject power into the circuit.
These are actually very complicated boxes inside, I think you'd need to be very hot on your electronics to make adapting one of these viable.BillB wrote:Not sure how adaptable / appropriate this is, but just a thought:
https://www.andertons.co.uk/guitar-dept ... s-with-jtv)
Users browsing this forum: Alba
