Tascam US 20x20 interface!!!
Postby pyaar » Wed Jan 09, 2019 6:15 am
Hi
Wonder if anyone here owns this interface and tried to figure it out:
I have a Tascam US 20x20 interface, and I'd like to see how can I route the headphone jacks so I'd be able to send different mix setting to each jack. I could do these settings with older interfaces I had in the past, but here from some reason I can't find how to tweak it, I tried to find it in the user manual, no luck - any thoughts?
pyaar
Re: Tascam US 20x20 interface!!!
Postby ef37a » Wed Jan 09, 2019 2:05 pm
According to this, https://www.soundonsound.com/reviews/tascam-us20x20
You can't. There are ten line outputs so it might be possible to route different tracks to those then drive a headphone amp?
Postby Music Wolf » Wed Jan 09, 2019 8:52 pm
I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones.
To use the multiple line outs you basically have to configure the unit as a multi channel mic pre with each mic directly feeding a line out.
Music Wolf
Postby blinddrew » Wed Jan 09, 2019 9:36 pm
Music Wolf wrote:I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones.
I've used my 16x08 with different mixes going to different pairs of line outs (configured in Reaper) but as Dave's mentioned above, I think the two headphone outs are both on the same feed.
Postby Music Wolf » Wed Jan 09, 2019 9:39 pm
Yes, you are correct. I was thinking about direct monitoring where you cannot do this :headbang:
Music Wolf
Postby blinddrew » Wed Jan 09, 2019 9:43 pm
Yep, so it does rather depend on how the OP wants to use it.
Postby pyaar » Fri Jan 11, 2019 6:44 pm
blinddrew wrote:
Music Wolf wrote:I have a 16x08, which doesn't see much use. On that model you have a single mix feeding both the line out and headphones downloader.vip/rufus/ appsync.biz/123movies/ ovo.fyi/gomovies/
my issue has beens solved!!!
______________________________________________
pyaar
Postby ef37a » Sat Jan 12, 2019 12:20 am
How?
And...WHO are you calling "Has beens"? !!
Dave
Users browsing this forum: pjchappy
