Octave pedal or guitar synth?
• Page 1 of 1
I want to be able to add bass line to rhythm guitar loops. I have tried a couple of octave pedals which are okay mixed in with the original guitar signal but pretty poor on their own (I'm sure I could improve things with more practice and better technique but probably not enough to get a credible bass track).
Today I nearly went out and bought a Boss RC-300 'super looper' which has a transpose function (not for that feature alone I hasten to add) but resisted the temptation.
Any reasonably priced suggestions (i.e. not a Fender GR ready Strat and Roland GR-55) which will generate passable bass guitar lines from a standard (and, usually, acoustic, which doesn't help) guitar.
Sam Spoons - Jedi Poster
Re: Octave pedal or guitar synth?
A bass and an A/B input switcher?
Wonks - Jedi Poster
Yup, already considered that but I'm thinking of it for busking/open mics so that's just too clunky....
Double neck? :D
Wonks - Jedi Poster
Sam Spoons wrote:I want to be able to add bass line to rhythm guitar loops. I have tried a couple of octave pedals which are okay mixed in with the original guitar signal but pretty poor on their own (I'm sure I could improve things with more practice and better technique but probably not enough to get a credible bass track).
Challenge with an octaver is that it's gonna affect the whole signal. You could split the guitar output to two independent loops with the ABY, placing the octaver and a an low-pass EQ in one and leave the other clean (or whatever ordinary signal chain you have).
CS70 - Jedi Poster
Maybe a bass FX might help improve the tone, add some amp SIM to round things out as the Octaver would be intended to feed a guitar amp.
Hewesy
Hewesy
- Hewesy
- Frequent Poster
Maybe one of these with an octave pedal would do the job.
https://www.submarinepickup.com
And reviewed in SOS too.
https://www.soundonsound.com/reviews/le ... -submarine
And here's something similar...
http://ubertar.com/hexaphonic/one_and_t ... ckups.html
zenguitar - Moderator
Yogi Berra
Yogi Berra
If you don't already have a looper, then the Boss RC-505 has a bass effect on input. I only use mine with keyboards, so I don't know how well it tracks guitars - could be worth a search on YouTube.
The Elf - Jedi Poster
Thanks guys......
I do have several loopers including a Boss RC-3 in the gig bag and an RC-30, neither of which have the transpose fx, so I was thinking of the RC-300 which, I suspect, much the same as the 505. As the purpose if to generate rhythm tracks on the fly for busking and open mic sessions anything that adds multiple extra leads and boxes is probably not practical. I have a cheap octave pedal and a couple of oldish multi fx (Boss GT3 and Digitech RP360) with octave/transpose functions but they're not great.
The Submarine is interesting but, as I'll be adding the bass line over the rhythm guitar part rather than at the same time the only real advantage would be being able to eq it differently to the normal pickup.
Maybe the way ahead is to eq the guitar for the cleanest signal with not too much treble so the octave pedal has the best chance of tracking it?
Is the Octave first in line? If you're using a Boss OC3 or something with split outs you could then EQ/FX each side and mix back together to hit the looper.
Hewesy
Hewesy
- Hewesy
- Frequent Poster
Thanks H, but that would require another box and more cables. I think eq-ing the guitar before the octave pedal might be worth a try as I suspect the issue is with tracking rather than the sound output from the pedal. I will experiment with that and with having the octave pedal first in line.
The problem is, I think, that of acoustic guitars and their abundance of overtones but for my needs an electric guitar is probably not an option (will try the Jazz box though).
A compressor might help before the Oct - I have found my OC3 prefers electric over my fingerstyle acoustic but that's probably just my playing.
Hewesy
Hewesy
- Hewesy
- Frequent Poster
I'll give that a try too, acoustic must be harder for the octave pedal to decipher than electric due to the higher overtones and less sustain. I think I'll revisit the RP360 and set up an eq/comp/octave fx chain just for the bass sounds, I can then bypass it for the 'normal' guitar sound. If that works the next job is build a Li-Ion battery pack into it :D
FWIW I’ve been using a Submarine with an acoustic into an MXR octave pedal. I eq the submarine signal pre the MXR. Not looping, more playing bass and rhythm at the same time (or trying to), or just bass lines.
Guy I was playing with did the same thing only he used an EHX pitch fork. The MXR sounds better to me but the EHX tracks better.
Cheers
A
Cheers
A
adrian_k - Frequent Poster
getting better all the time..
Just been playing with my cheapo pitch pedal and, an octave down, it is very 'warbly' even with all the top rolled off (with a way pedal as that is what's on the board). It's not at the front of the sig chain as I use it for chorus/detune on my electric board (for fusion style lead with distortion and delay). I suspect it's simply not very good so I may go and try the Boss along with the RC-300 octave fx
If it's anything like the 505 it should be OK, if not amazing. I wouldn't roll the top off, though - the more the tracking has to bite on the better.
Thanks Elf, not having to do extra eq and stuff would be a good thing. I'll go and have a play with one later in the week.
Just been and bought a Boss RC-300. It has a "Guitar>Bass" effect which works pretty well as long as you stick to the bottom octave but if you go higher it gets very 'warbly'. Good enough for my needs I think (and significantly better than the cheap octave pedal). It has more stuff on it than you can shake a rhythm stick at so should keep me amused for a while.
