W10 PC suddenly 'Read Only" files?
Postby james090 » Sat Feb 09, 2019 3:57 pm
Using a W10 laptop fine, and formatted a USB3 drive with exFAT so I can access my files with my W10 PC and MacOS.
All is fine, however in Windows 10, after I have dragged some large folders to this drive, W10 in 'properties' is telling me these folders are suddenly 'Read-Only' ??
I did untick this and APPLY, and it went through all the files in the folder for 10 minutes, and seemed fine. Just checked again and its gone back to 'Read-Only' ??
I am the only user, so would like to access, read, modify and have full permissions for these files (mine!) on this drive regardless of Mac or PC access?
Am I doing something daft? or is there an easy way to rectify this?
Thanks!
james090
Re: W10 PC suddenly 'Read Only" files?
Postby Eddy Deegan » Sat Feb 09, 2019 4:25 pm
This sounds like an inheritance issue with file permissions. Annoying, I know.
Try this:
  • Plug the USB drive in
  • Right click on the drive icon in for the USB device (you can find it under "This PC" in the left hand panel of a file window), and select Properties
  • Select the Security tab
  • Click Advanced
  • Click Change permissions
  • If your username is shown, skip the next step
  • If your username is not listed, click Add and in the resulting dialogue box click Select a principle, type your username into the box and then click Check Names. If you do this correctly, your name will appear underlined in the box and you can click OK to add your name to the list and return to the previous dialogue box
  • Select your username and click the Edit button that will become active when you do
  • Ensure that the "Applies to" drop down is set to This folder, subfolders and files
  • Ensure the Full control box is checked
  • Click OK
This should recursively reset all the permissions associated with the drive for your username from the root down. It might take a little while depending on the number of files on the USB device. Hopefully will solve the issue - but if not, let us know.
Some of my works
Postby james090 » Sat Feb 09, 2019 5:21 pm
Thank you Eddy. I will try this and let you know how I get on.
Also on this subject, as I’ve formatted as exFAT I don’t seem to get the option to “eject” anymore on W10?
Do I just put the laptop to sleep in order to remove the drive or is there another way?
I don’t really want to just disconnect and this do damage over time and I lose all of my files in 6 months due to disconnecting wrongly!
james090
Postby Eddy Deegan » Sat Feb 09, 2019 5:53 pm
Hmm, no idea why you can't eject it - you should be able to. I wouldn't consider putting the computer to sleep to be that safe to be honest, really the only guaranteed way would be to shut the system down altogether.
Are you sure you can't eject it? Maybe the icon just isn't showing on your taskbar. If you right click on the drive icon the 'eject' option should appear in the context menu, or alternatively if you click on the little icon that looks like an arrowhead pointing upwards, right at the end of the task bar then you should be able to find an eject icon in the little group of icons that pops up.
Some of my works
Postby Eddy Deegan » Sat Feb 09, 2019 5:57 pm
james090 wrote:I don’t really want to just disconnect and this do damage over time and I lose all of my files in 6 months due to disconnecting wrongly!
Uhh... you really should have these files backed up somewhere else as well, not just on a single drive!
Some of my works
Postby Wonks » Sat Feb 09, 2019 5:58 pm
If in any doubt, turn the PC off and pull the drive out then.
Postby james090 » Sat Feb 09, 2019 7:18 pm
Thanks for the replies.
1. Yes I do have these files backed up elsewhere.
2. I can't see any 'Eject' on the drive. I usually right click the drive in question, and i see eject?
But not this time. I think it maybe the exFAT format?
This does seem weird, as something as hot swappable as a USB drive, really disrupts your workflow if i have to keep fully re-booting each time to remove?
james090
Postby James Perrett » Sat Feb 09, 2019 9:51 pm
I find the same thing with Windows10. I can eject USB memory sticks but not USB hard drives.
Postby CS70 » Sat Feb 09, 2019 9:53 pm
Do you have "desktop.ini" in the folders that are read only directories? (you may need to enable "show hidden files" to check).
Postby CS70 » Sat Feb 09, 2019 10:09 pm
Also, if you don't see the eject option is usually because the disk is in "quick removal" mode and the caching is disabled. Meaning all write ops are committed immediately and you can just unplug the disk whenever you like.
Postby james090 » Sat Feb 09, 2019 10:18 pm
CS70 wrote:Also, if you don't see the eject option is usually because the disk is in "quick removal" mode and the caching is disabled. Meaning all write ops are committed immediately and you can just unplug the file whenever you like.
Oh really? maybe its this then with regards eject? So i can just pull it at anytime? (I'd never heard of this til now, so was always told to be super cautious) :)
james090
Postby wireman » Sat Feb 09, 2019 10:31 pm
CS70 wrote:Also, if you don't see the eject option is usually because the disk is in "quick removal" mode and the caching is disabled. Meaning all write ops are committed immediately and you can just unplug the disk whenever you like.
I'm amazed this is an option in the OS for anything other than a read-only device.
Who has the skill to know that Windows or some app is not writing to a device at any given time?
wireman
Postby CS70 » Sat Feb 09, 2019 10:42 pm
I guess that's why it's become the default.
Back in the times, solid state memory in the form of USB sticks was quite slow (and expensive and not so common) so having the caching mechanism gave a real edge. And the idea of waiting before unplugging, or "ejecting" the disk comes exactly from there.
Synchronous write has been the default since Windows 7, I think (but not sure, it's been a while now).
Postby Wonks » Sat Feb 09, 2019 10:48 pm
If you can remember floppy disks, you simply ejected them once the system had stopped writing to them, with no issues at all. Unless your external hard drive is configured as a system drive, it should be pretty safe to unplug once any file transfer procedure is completed. For some reason USB stick handling is different, with windows writing to and checking the drive's file tables fairly constantly. Probably a good reason behind it but it still seems rather stupid to me.
Postby CS70 » Sat Feb 09, 2019 10:49 pm
Yes. Well no, don't pull it when you're writing a file, or you will lose that one file. But if you aren't doing anything on the disk , it's fine. Open Device Manager and right click on you disk - one of the tabs is the "policies". If it's in "quick removal" you're alright.
I keep my USB disks on write cache because I also work with video and it's still a little advantageous (and the disk is never removed anyways), but with USB3.0 I could probably use the synch write.
