LR Baggs Para DI - lack of earth lift problem
Re: LR Baggs Para DI - lack of earth lift problem
Postby lukatosh » Mon Feb 11, 2019 12:59 pm
Hi everyone,
i'm Lucas and i'm writting from Chile! Well... i've arrived here looking after a solution to the same issue.
Apperently, I can't send PM since i'm a new user (i think...) is there a way that you could share the schematic trough mail?
Best regards!
lukatosh
Postby Hugh Robjohns » Mon Feb 11, 2019 1:44 pm
Welcome to the forums -- and yes, the PM system is inhibited for newcomers until they've reached more than three posts.
I've removed your email address from the post above to prevent the spambots harvesting it.
Dave -- if you email the schematic direct to me I'll embed it in the forum thread for all to see for posterity.
Postby Hugh Robjohns » Wed Feb 13, 2019 2:10 pm
Here is a schematic for Dave's ground lifting box with adjustable output level:
And here's the original:
Postby Wonks » Wed Feb 13, 2019 2:45 pm
I'd use plastic jack TRS sockets for 'in' and 'loop'. Probably easiest to use a guitar all-metal type TS jack socket for the 'out', as it saves having to make a separate ground connection to the case (which should be metal, not plastic, for shielding purposes).
Postby ef37a » Fri Feb 15, 2019 10:09 am
Wonks wrote:I'd use plastic jack TRS sockets for 'in' and 'loop'. Probably easiest to use a guitar all-metal type TS jack socket for the 'out', as it saves having to make a separate ground connection to the case (which should be metal, not plastic, for shielding purposes).
Wonks, I loathe and detest those "bent tin, horrible imerican" jacks! Because of that I never consider telling people to use anything other than plastic!
Well poshed up Hugh, ta!
Postby Wonks » Fri Feb 15, 2019 10:16 am
Well, considering that's what's in almost all electric guitars (either that or the much more failure prone barrel jack socket), and that a good Switchcraft jack socket will happily last 30 years plus, I don't see what you can really have against them.
Postby ef37a » Fri Feb 15, 2019 11:15 am
Wonks wrote:Well, considering that's what's in almost all electric guitars (either that or the much more failure prone barrel jack socket), and that a good Switchcraft jack socket will happily last 30 years plus, I don't see what you can really have against them.
The one in my lad's Strat has been bent and I had to fix it. I guess my hatred came from early days when I encountered them in cheap, Eagle and Radshak gear?
They do not of course naturally earth isolate and to me just LOOK gash and cheap.
