Higher latency in a particular project
Postby Ylan Sthlm » Sun Jul 14, 2019 6:17 pm
Dear Sirs and Madams,
I am trying to record a track in project, but suddenly I get a lot more latency, and not only in my headphones, but also on tape as it were.
I have a fairly recent mac (iMac 2017, 27" i5 3.8 GHz and SSD and Logic, latest version, and Focusrite Clarett 4 pre, Thunderbolt), and even after having bounced all drums, and turned off the drummer track and frozen all other tracks I get a considerable latency, that I haven't heard before.
If I open a new project, it's gone.
Does anyone know what could be the problem?
Humbly Ylan
Ylan Sthlm
Re: Higher latency in a particular project
Postby Ylan Sthlm » Sun Jul 14, 2019 8:32 pm
I might add, that I moved the project via a thumb drive to a much slower Mac (MBP 13", 2012) to bring to a summer house. Then I moved it back to my iMac, might this have screwed someting up?
Humbly, Ylan
Ylan Sthlm
Postby CS70 » Sun Jul 14, 2019 9:03 pm
Ylan Sthlm wrote:Does anyone know what could be the problem?
Do you have any plugins active? When you record, you shouldn't have any, or just the minimal you need - like a synth you're playing for example.
Postby desmond » Sun Jul 14, 2019 9:05 pm
Have you tried enabling Low Latency mode in Logic for recording?
You might have placed latency-inducing plugins in your mixer, which causes Logic to delay things to keep everything aligned.
Low latency mode temporarily turns off plugins that cause more than a small amount of latency, so you can track without having to remove them first.
desmond
Postby Ylan Sthlm » Sun Jul 14, 2019 9:17 pm
And fascinatingly enough the latency is there even if I don't play the project, but only listen to my own handclap. Sounds like a slap delay.
And Logic says my roundtrip latency is 2.7 ms.
http://ylan.nu/filer/Latency.jpg
Humbly, Ylan
Ylan Sthlm
Postby Ylan Sthlm » Sun Jul 14, 2019 9:28 pm
Thank you!
I started the project again (which I have done a couple of times, also computer and interface, to no avail) and now it's suddenly gone.
And I had removed all plugins. And as i wrote above, I could have several plugins on a test project I started.
I have no idea what might have gone on. Has anyone had this happen to them?
Humbly, Ylan
Ylan Sthlm
Postby Eddy Deegan » Sun Jul 14, 2019 9:29 pm
Uh, this might be a stupid thing to ask but you don't have a delay insert somewhere which is set to 100% wet do you?
Just mentioning it in case. I've done it before...
Some of my works.
Postby Ylan Sthlm » Sun Jul 14, 2019 9:35 pm
Eddy Deegan wrote:Uh, this might be a stupid thing to ask but you don't have a delay insert somewhere which is set to 100% wet do you?
That could very readily had been the case, but this time I removed everything.
And for you other helpful people, I bought my Clarett Thunderbolt to be able to track with some reverb. And it has always worked before, and is again. :clap:
Humbly, Ylan
Ylan Sthlm
Postby Eddy Deegan » Sun Jul 14, 2019 9:43 pm
I'm not sure if you mean that the problem is now fixed or whether it is still there :)
If it is still there, but it is not a problem on other projects then this is almost certainly something to do with the project itself.
If you cannot fix it any other way then my suggestion would be to create a new project, verify that the latency is not on the new project, and then copy over the audio tracks from the old project to the new project.
As you do this, keep checking to make sure that the problem has not started on the new project.
Hopefully one way or the other you will have a solution!
Some of my works.
Postby Ylan Sthlm » Sun Jul 14, 2019 10:16 pm
Eddy Deegan wrote:I'm not sure if you mean that the problem is now fixed or whether it is still there :)
Cheers!
Yes, I will do that. Because it's not entirely gone. It's not as obvious, but when I listen back to the recording, I'm seemingly less tight than I normally am.
I'll bounce out the audio and put it in a new project and move on from there.
Humbly, Ylan
Ylan Sthlm
Postby Eddy Deegan » Sun Jul 14, 2019 11:12 pm
You shouldn't need to bounce :)
In Logic if you have two projects open at the same time then you can copy and paste between them... at least I used to do that some time ago. I don't use logic these days but I would be surprised if that's changed now.
Some of my works.
Postby MOF » Sun Jul 14, 2019 11:26 pm
Have you ticked low latency mode?
MOF
Postby awjoe » Mon Jul 15, 2019 12:58 am
In Audition, there's an I/O Buffer Size, which I set to max for mixing (2048). The other day, having forgotten to change the buffer size, I started recording something and the lag was so big it was impossible to play - like when you heard the latency when you were listening to your own handclap. Anyway, I reduced the setting to 256 and everything was fine for recording. Desmond and MOF mentioned a low latency mode in Logic - have you looked at that? And is that the only way to change latency in Logic?
awjoe
Fringe member of the Party Pooper People's Party
Postby blinddrew » Mon Jul 15, 2019 9:33 am
Not sure how the Clarett software works but the Scarlett mix software has a latency setting - worth looking at if you haven't already.
Postby Ylan Sthlm » Mon Jul 15, 2019 10:44 am
MOF wrote:Have you ticked low latency mode?
Cheers!
No I didn't, but I think there must have been something wrong then and there in that project. Processor use and IO was fine. I don't know whether you saw above, but the latency is supposed to be 2.7 ms (since it is a Thunderbolt interface and a fairly fast computer) and I didn't start any new heavy plugins, and wasn't bothered by any dropouts or clicks/pops. Furthermore I tried to freeze all other tracks and disable all plugins, so it definitely was something else going on.
Humbly, Ylan
Ylan Sthlm
Next
