Izotope RX 5 - Removing section of audio and fading in/out to create seamless transition
Postby uwish95@gmail.com » Mon Jul 15, 2019 1:41 pm
I am currently using RX 5.. I was at a field recording workshop last week, and someone did an RX 7 demonstration. I am unsure if I can do what they were doing with my version, but they somehow created a fade out, and a fade in, and removed the unwanted section of audio between them creating a seamless transition. I know they used equal power fades, and reduced feathering to 0 (I cannot find the feathering option in 5), and I think they somehow copied the fade out and overlaid it over the fade in, or something like that. I hope this makes some sense... I cannot figure out how to do it. Any help would be appreciated!
Cheers,
James
uwish95@gmail.com
Re: Izotope RX 5 - Removing section of audio and fading in/out to create seamless transition
Postby Mike Stranks » Mon Jul 15, 2019 2:47 pm
Welcome!
I may be (probably!) missing something, but whatever software you're using, isn't it just the case that you fade to zero at the appropriate point, fade from zero at the other point and then delete the audio between those two points?
I have RX6 Elements so I'll have a look at that to see if I can be more precise...
Postby Mike Stranks » Mon Jul 15, 2019 3:07 pm
Just tried 'my' approach in RX6 - I don't normally use RX for editing - and it worked fine.
If you don't want to go to/start from absolute zero, after you've deleted the unwanted section you simply delete a tiny bit more audio, bridging the absolute zero point.
Forgive my ignorance, but being a simple soul, 'Feathering' is not something I'm familiar with.
Postby Hugh Robjohns » Mon Jul 15, 2019 3:39 pm
uwish95@gmail.com wrote:I am unsure if I can do what they were doing with my version, but they somehow created a fade out, and a fade in, and removed the unwanted section of audio between them creating a seamless transition. I know they used equal power fades, and reduced feathering to 0 (I cannot find the feathering option in 5), and I think they somehow copied the fade out and overlaid it over the fade in, or something like that.
Hard to know what they did without the context.
However, I can tell you that selection feathering is available in RX5. Go to the Edit drop-down > Preferences > Misc Tab > bottom slider. Feathering sets the crossfade time between processed and unprocessed audio.
Also, if you're performing a cross-fade edit on a track it is normal to use the equal power fade curve which gives a seamless junction. Other fade shapes typically result in a level bump or dip at the centre of the cross fade.
Postby Mike Stranks » Mon Jul 15, 2019 3:48 pm
As I have an unexpected window...
This is what I meant.... crude and clunky maybe....
https://youtu.be/hivsyzOtP0g
but I shall continue experimenting... :)
