Roland MC-500 incoming!
Re: Roland MC-500 incoming!
Postby Adam Inglis » Fri Jul 19, 2019 1:09 am
Yeah, the Rhythm Track editing is a bit clunky, but the Rhythm Pattern writing is really quick if you use a sustain pedal with your keyboard controller - it erases whatever note you are holding down.* This way you never have to drop out of record, you just build it up while looping, and if it get's too messy or busy, just hit the pedal and hold the notes to make some space or start over.
And you do know you can copy rhythm patterns of course (just gotta get used to those key commands). This allows you to do the following to speed up the rhythm writing process:
Write a "Rhythm Track" quickly by entering Write and hitting... [Enter] [1] [Enter] a bunch of times to put Rhythm Pattern 1 in the track (you can use the Edit Copy commands if you need to extend this further). Now in Rhythm Pattern write, copy pattern 1 to somewhere else and keep editing or tweaking Pattern 1. When you get something you like, copy it again and then erase or tweak Pattern 1. You're basically using Pattern 1 as an edit buffer, without having to mess around with changing the Rhythm Track. This way you can test your patterns against the rest of the music. After a while, you'll have a bunch of patterns saved that you can then sequence into a Rhythm Track.
*on the MC-50 at least. The "Super MRC" operating system is almost identical in it's implementation on the 500, so I would expect it to work there as well. There is a manual called Super MRC Advanced Course that would detail this, however I can't find it on the webs, just the Basic Course. The MC-50 manual explains it.
Adam Inglis
Postby Ben Asaro » Fri Jul 19, 2019 4:47 am
Ha, that’s pretty much how I ended up using it as well!
I have both the Basic and Advanced Super MRC books, and I even scored a sealed, NOS MRP 500 disk and manual. That basically makes the MC-500 useful to me because my songs tend to be on the long side. :)
Ben Asaro
Postby Ben Asaro » Tue Jul 23, 2019 4:11 pm
Well, yesterday was Do or Die day -- after weeks of programming, arranging, tearing down, and re arranging, I had two songs programmed into the MC-500 and laid out in the NerdSeq. To prove that this can be performed live I had to chain them together press play, and hope it worked.
After several rounds of trial and error, I was able to get everything to work! It was mostly due to discovering a few of the idiosyncrasies of the MC-500 and then finding out how to work around them.
NOTE: I am using the MRP-500 Performance Data OS for Chain Play of the songs.
There is nothing in the manuals about this stuff aside from telling you how to access it, no considerations of how important they are or how they impact performance, so I am setting it down for posterity here. :)
IDEOSYNCRACY NO. 1: ADDITIONAL MEASURES. When you record in real time with the MC-500, it automatically adds a measure to the end of the track you are recording on. This is fine on its own, but when you are chaining songs together, that extra measure sends clock to the modular and throws the sync off when you switch songs. You have to remember to trim the song down to the actual measures used so that the transition will be smooth during Chain Play.
IDEOSYNCRACY NO.2: 'BASIC TEMPO'. There is NOTHING basic about this setting! Without saving the tempos of your song, the MRP-500 will not play your songs in the correct tempos! So, whilst you are still in Mode 1 (MIDI Recorder) of the MRC-500, you MUST save the Basic Tempo setting if you want it to play correctly when you use the MRP-500.
IDEOSYNCRACY NO.3: AUTO-PAUSE. Auto-Pause essentially works in reverse; not only do you have to disable it on every song in a Play List if you are chaining them together, but it sets the Pause command before the song in question, not after it. So, logically, you may think -- okay, I have five songs and I want it to pause after Song 4, so I will set Auto-Pause on 4 ... nope, you would need to set it on Song 5!
Ben Asaro
Postby Ben Asaro » Thu Aug 01, 2019 1:00 pm
The new piece of music is coming along, I am putting the finishing touches on the third and fourth parts (it will have around five parts in total). I bought a couple of things to make my life easier — a new 6U/104hp case and a BOSS RV-500; that prompted a synth shelf re org which was actually a nice diversion from all this madness! Everything is within better reach now, less precariously stacked, and neater. So, win/win!
However, I did want to post another revelation regarding MC-500: R-PTN and R-TRK use up a LOT of system memory! So when you are planning out your song, unless you need very intricate drum parts, it’s best to keep it simple. I suppose since R-PTNs are polyphonic, they add significantly to the overall note count. LESSON: press AVAIL MEMO often! And have an exit strategy!
Fortunately, the tempo for this song is 85 bpm so even though each part has a low measure count, it takes a couple of minutes to get there! :)
I did want to say something about using this old gear as well. The more work I do away from the computer, the happier I am. I definitely feel that making music DAWlessly is more immersive to me. In particular to how this relates to old gear, however— old doesn’t mean useless! The MC-500 is (overall) intuitive to use, gets the job done, and there are plenty of them floating around! I would rather see them used than adding to the rubbish heap.
There is a sense of tactile satisfaction from the oversized futuristic looking boxes, the clacking mechanical keys, and just a weighty presence. (I will still be gigging with backup stems on my iPad, however!!!!)
Ben Asaro
Postby MC 500 » Mon Aug 19, 2019 8:34 am
i also bought a Roland MC 500 some time ago. It is really a great hardware sequencer.
I am also interested in knowing how to copy the rhythm tracks of the MRD-500 Rhythm Bank Software package demosongs to tracks 1-4 in order to modify them with my Waldorf MicroQ synth. Unfortunately the manual for MRC 500 OS is of no help here.
Have you ever tried that ?
Thanks in advance and best regards from Berlin,
Tim
MC 500
Postby Ben Asaro » Mon Aug 19, 2019 1:08 pm
I haven’t accessed the demo material but will have a look!
I am now using the MC-500 every day and it’s slowly revealing its secrets. :)
I did a small series on memory-saving strategies on Instagram and am also documenting my songwriting process with the MC-500. My Insta handle is @postcardsfromjupiter8 if you’re interested.
Ben Asaro
Postby Adam Inglis » Wed Aug 21, 2019 2:53 am
MC 500 wrote:I am also interested in knowing how to copy the rhythm tracks of the MRD-500 Rhythm Bank Software package demosongs to tracks 1-4 in order to modify them with my Waldorf MicroQ synth.
It might have to be a two or three part operation. I've not tried this myself, but on the MC-50, you could use a UTILITY function ("Copy Rhythm Patterns") to get the pattern data into a new song, and then use Mode 3 Song Link, to link those songs together, to get access to the Rhythm Track data, which can then be copied to a Phrase track for further editing.
In theory... ;-)
Actually, maybe you wouldn't even need to do the first stage, Song Link might be all you need.
Adam Inglis
Postby Adam Inglis » Wed Aug 21, 2019 6:02 am
Hang on, why doesn't simple EDIT {10} COPY work? Click thru the defaults til you get to the track page, then hit the Rhythm track's mute button to select it, and cursor to the destination track, hit a track number, specify the bar number, usually 1 (unfortunately defaults to "End") and..done! Save as a new song.
If you need to spread the drum voices out over several tracks, you would then use the EDIT EXTRACT function.
Adam Inglis
