microphone case options
Postby forumuser653351 » Fri Jul 19, 2019 5:19 pm
Hello
I’m looking to get a case to put all my microphones in for when I go on location. The main reason is to keep the mics protected and reduce the amount of stuff to carry - rather than keeping them in their separate boxes.
Current mics are: Neumann TLM 102, Lewitt LCT 441, Line Audio CM3 pair and MBHO SDC pair. Hoping to add a pair of Line Audio OM1 and another LDC soon. Shock-mounts, clips etc I can store separately if need-be.
I’ve found a couple of possibilities: http://www.pulse-audio.co.uk/product/acc-case-m/ and: https://www.thomann.de/gb/thon_flex_cut_universal_mischpult_1.htm
Has anyone got any other suggestions?
Thanks in advance.
Ian
forumuser653351
Re: microphone case options
Postby blinddrew » Fri Jul 19, 2019 5:27 pm
Might be worth looking at a mic-specific case, something like this perhaps: https://www.studiospares.com/Accessorie ... 459010.htm
Postby Sam Spoons » Fri Jul 19, 2019 5:35 pm
I was also going to suggest something similar but then spotted the OP has two LDCs (and another in the pipeline) and they don't look well suited to large diaphragm mics.
I've been wrong before though..........
Postby forumuser653351 » Fri Jul 19, 2019 6:01 pm
Sam Spoons wrote:I was also going to suggest something similar but then spotted the OP has two LDCs (and another in the pipeline) and they don't look well suited to large diaphragm mics.
It could work, I'll have to measure my LDCs.
forumuser653351
Postby forumuser653351 » Fri Jul 19, 2019 6:02 pm
blinddrew wrote:Might be worth looking at a mic-specific case, something like this perhaps: https://www.studiospares.com/Accessorie ... 459010.htm
Thanks, there's a few options on the website.
forumuser653351
Postby Hugh Robjohns » Fri Jul 19, 2019 6:08 pm
The studiospares case only really works for a bunch of handheld vocal mics. SDC pencil mics tend to rattle around and LDCs just don't fit nicely at all.
Personally, I use hard-shell camera cases with diced foam interiors which can be cut or picked out to provide unique orifices for any collection of disparate mics.
This kind of thing:
https://www.amazon.co.uk/Waterproof-Large-Protective-Camera-Case/dp/B00S86TL30
These 'Peli-esque' style cases have the benefit of airtight seals, which is handy for keeping the mics dry if you need to store them in a damp garage etc.
Postby forumuser653351 » Fri Jul 19, 2019 6:13 pm
Hugh Robjohns wrote:
This kind of thing:
That sort of thing looks great, much better price than the flightcase style.
forumuser653351
Postby blinddrew » Fri Jul 19, 2019 6:26 pm
Ah, thanks Hugh, wasn't sure how adaptable they were.
Postby Hugh Robjohns » Fri Jul 19, 2019 6:32 pm
Very.
Typically, the foam is diced into 1cm cubes, so you can adjust the depth, width and length of each slot to +/-5mm, in effect. I have everything from tiny KM84s, up to an SM69 and SoundField mic in my cases, with all manner of SDCs, LDCs, and live-sound mics in between. Those with fiddly shock-mounts are stored with the shockmounts attached.
I've used these cases for over twenty years very successfully.
Postby Hugh Robjohns » Fri Jul 19, 2019 6:35 pm
forumuser653351 wrote:That sort of thing looks great, much better price than the flightcase style.
I should say that I've not used that particular case, so can't vouch for it specifically, but there are many similar variations on that theme. Peli are the leaders in that kind of case, but they are pricey. The Chinese knock-offs aren't as well made, but most are perfectly adequate and a great deal cheaper.
Postby Mike Stranks » Fri Jul 19, 2019 6:45 pm
I have a very heavy-duty Gator mic case which I've had for maybe 15 years. Built like the proverbial. I take the point about SDCs rattling around, but I store them with clips on - keeps them snug. Also my SDCs have always fitted OK - again sometimes a snug fit.
I've bought several 'diced foam' cases and other cases from these guys:
https://www.cases-and-enclosures.co.uk/products
Always been well-pleased.
Postby forumuser653351 » Fri Jul 19, 2019 7:01 pm
I definitely can't afford a Peli :(
Quite a lot of choice of this sort of case on Amazon, just a case of seeing which dimensions best fit my mics.
forumuser653351
Mike Stranks wrote:I have a very heavy-duty Gator mic case which I've had for maybe 15 years. Built like the proverbial. I take the point about SDCs rattling around, but I store them with clips on - keeps them snug. Also my SDCs have always fitted OK - again sometimes a snug fit.
Thanks, I shall have a look.
forumuser653351
Postby shufflebeat » Fri Jul 19, 2019 8:19 pm
I use one of these:
https://www.screwfix.com/p/stanley-fatm ... gKbK_D_BwE
Bring your own diced foam.
Bigger models exist, of course.
shufflebeat
Postby Bob Bickerton » Fri Jul 19, 2019 9:34 pm
I use Pelican cases and either use the supplied diced foam or make bespoke inserts using museum foam.
To my mind they are not expensive at all given the cost of what they’re protecting!
Bob Bickerton
http://www.bickerton.co.nz
