Using Roland PK-5A floor pedals with Laptop Programs
Postby AMOS63 » Sun Jul 21, 2019 7:57 pm
Hi all, I'm having a hard time interfacing my Roland PK-5A pedals to my Laptop via a Roland Um-One MIDI to USB interface, the driver is installed and I can see that under options in Reaper, but I can't play any patches.
I'm attempting to utilize Omnisphere so I can play patches using the foot pedals while playing bass, guitar or cello. Does anyone have any experience running this sort of MIDI application? I had success using my Korg X3 as a MIDI keyboard with Reaper/Omnisphere but can't get there using the PK-5 as a controller. Thanks!
AMOS63
Re: Using Roland PK-5A floor pedals with Laptop Programs
Postby The Elf » Mon Jul 22, 2019 11:07 am
Make sure you have the correct MIDI port and channel selected. Some screenshots might help us to see how you have it set up.
If you use a different MIDI controller, does that work?
Postby AMOS63 » Tue Jul 23, 2019 3:49 pm
Yes my Korg X3 works fine as a controller, with the PK-5 I can see the lights moving on the track but it produces no sound.
AMOS63
Postby The Elf » Tue Jul 23, 2019 8:42 pm
Then it very much sounds like the PK5 are transmitting on the wrong MIDI channel - check that first.
Postby AMOS63 » Tue Jul 23, 2019 11:48 pm
I know the PK-5 transmits on 2 but I'm not sure how to change the MIDI channel in Reaper, I didn't think software required that. it's usually install the driver then plug and play after that.
AMOS63
Postby The Elf » Wed Jul 24, 2019 8:46 am
AMOS63 wrote:I know the PK-5 transmits on 2 but I'm not sure how to change the MIDI channel in Reaper, I didn't think software required that. it's usually install the driver then plug and play after that.
Just getting MIDI in and out is not enough - MIDI channels still need to be correct! Most DAWs will re-channelise for you, but maybe you have something set that's not doing this. Hard to say without being there, but it seems likely, given that your other controller works.
Rather than trying to get Reaper to re-channelise, at least to test the theory, just ask the PK5 to transmit on the same channel as the controller that works.
Postby blinddrew » Wed Jul 24, 2019 10:27 pm
Changing the midi input channel in reaper is straightforward, right click on the input and you select both the source and target channels.
IIRC - i'm away from a machine at the moment...
Postby AMOS63 » Fri Jul 26, 2019 11:33 am
Thanks, I'll try that right after work
AMOS63
Postby AMOS63 » Sat Jul 27, 2019 4:23 pm
I decided to try it with my desktop and it worked right away without making any changes. The only thing different is I use an ASIO driver in the desktop. I'll take some screenshots so I can compare the settings with the laptop.
AMOS63
Postby The Elf » Sat Jul 27, 2019 6:02 pm
ASIO is irrelevant in the context of what you've described. ASIO doesn't have anything to do with MIDI.
There *must* be another difference in the way you have it set up.
Postby AMOS63 » Sat Jul 27, 2019 7:25 pm
I agree
AMOS63
Postby Wonks » Sun Jul 28, 2019 8:13 am
Is the desktop MIDI via an audio interface with hardware MIDI sockets, or are you still using the same hardware MIDI to USB interface? If the former, it could simply be that the USB interface is faulty. I had a friend who spent ages trying to get a keyboard to work with an iPad with a cheap interface, but in the end bought another (slightly more expensive) interface and it worked straight away.
Postby AMOS63 » Sun Jul 28, 2019 6:50 pm
I'm using the Roland UM-One MIDI to USB adapter. it's running fine on my laptop now, I think it always was! It's just not voicing all of the Omnisphere patches though, not sure why, but the patches where it doesn't create a sound, it only moves the input signal strength bar in my DAW. With native Instruments it runs Massive and Absynth 5 perfectly.
AMOS63
Postby Wonks » Sun Jul 28, 2019 6:59 pm
I don't know Omnisphere but it sounds like similar symptoms to when I use a Kontakt instrument and the input is outside the range of the instrument being played. You see the MIDI indicator light, but no sound comes out.
Might be worth checking to see if there's an input range note restriction on those Omnisphere patches that don't sound. You are playing low bass notes after all.
Postby AMOS63 » Sun Jul 28, 2019 7:43 pm
I'll check that out, I did change the octaves on the PK-5 pedals to see if the patch was very high or low but it made no difference.
AMOS63
Postby The Elf » Sun Jul 28, 2019 7:47 pm
Record a few notes and look in your MIDI editor to see what note numbers are being generated.
Users browsing this forum: Pete Kaine, Wonks
