Large PPM plug-in?
Re: Large PPM plug-in?
Postby Hugh Robjohns » Mon Jul 29, 2019 3:13 pm
Yes, I was aware of the Cubase customisable meter. SADiE allows it too. And my Nagra VI recorder. I haven't found the option in Reaper... Adobe Audition transitions to yellow at -18dBFS, and red at -6dBFS -- the latter being unhelpfully high. There is a gradient mode too, but that's no better.
Postby Arpangel » Mon Jul 29, 2019 3:47 pm
I'm flying blind, a bit, I just need a reference level somewhere along the line.
I'm using one of Mike Skeets mic preamps, it has no meters, I'm recording into Reaper, through my Motu, I guess I could use the meters on the Motu, but those are really tiny, and very dim. There is a a Tape Talk "The Box" on top of my preamp, but it's not really a level meter, great for phase and stereo field, but too vague for level. Like a lot of DAW's, I can't adjust the level going onto the actual track, it has to be done on an external device.
I must admit, this engineering and playing lark is a real pain, especially with mic's, it takes us more time to set up than we have to play
Postby OlinOvid » Tue Oct 08, 2019 2:56 pm
Hi...What are the ballistics of PPM/BBC and PPM/EBU? 10ms rise/2,8s fall to -24dB?
And why is it that the reference is 7? Unless -18dBFS = 4 (BBC) and/or TEST (EBU). Then that's still a 18dB jump from 4 to 7 (3dB) - something can't be right.
What is the measurement window for the RMS meter? 300ms? 400ms (ITU-R MLk)? 600ms?
And why do you write "standard K-Meter modes, based on ITU 1770" - then it's basically a "K-weighted meter" (aka ITU-R BS.1770-0 or even 1), and not a default RMS realtime meter. Meaning, we have the same +3dB compensation/offset topic we had with dpMeter, no?
OlinOvid
Postby Hugh Robjohns » Tue Oct 08, 2019 9:22 pm
OlinOvid wrote:Hi...What are the ballistics of PPM/BBC and PPM/EBU?
They are the same; only the scale is different. The specs are defined in IEC60268-10 iia (BBC) and iib (EBU).
Integration time was 10ms. I think it was increased to 4ms in later versions of the spec. Off the top of my head the fall time is 20dB in 1.5 seconds.
It isn't. The reference level on the BBC PPM is '4' which equates to 0dBu. On the EBU-scaled version, it's 0dBu/Test -- but both are at the point where the pointer is vertical.
Something isn't right... and I'm afraid it's your understanding... :-)
There's 4dB between each of the marks on a BBC PPM, so the level difference between PPM4 and PPM7 is 12dB. Like all analogue meters, there is headroom above the top of the display scale and the system's clipping level.
Normal programme peaks should be no higher than PPM6 (which is +8dBu on a steady tone), and PPM7 is achieved with a steady tone at +12dBu. But these readings are 'slugged' by the 10ms integration time, which means that brief signal transients will actually reach higher levels than the meter suggests, typically by about 4dB.
For that reason, the EBU decided that when digitising analogue signals controlled with a PPM, the alignment levels should be PPM4 = -18dBFS. So, although the mix should be restrained to PPM6 (allowing digital peaks to about -6dBFS) an occasional slip that displays as PPM7 (+12dBu) will actually have transients 4dB higher, and thus reach -2dBFS... which is as close to clipping as anyone would ever want to get! ;-)
I'm not sure that RMS meters have a defined integration time. VU meters are 300ms, but I've seen RMS meters with integration times of 300ms to 1 second...
The K-meter -- as in Bob Katz' metering system -- has nothing whatever to do with ITU-R BS.1770. It is a simple RMS-based meter with an adjustable headroom margin, but a standard reference level which is aligned to a specific acoustic reference SPL. It is intended to aid mixing and mastering of material with different, genre-based, amounts of dynamic compression.
The K relates to its inventor, Bob Katz, and not the K-weighting EQ which forms a critical part of the ITU-R BS.1770 loudness metering standard.
...then it's basically a "K-weighted meter" (aka ITU-R BS.1770-0 or even 1), and not a default RMS realtime meter. Meaning, we have the same +3dB compensation/offset topic we had with dpMeter, no?
[/quote]
Sorry... I think my babel fish has gone to sleep... ;-)
