Price of RW3 Rockwool...
Re: Price of RW3 Rockwool...
Postby Kwackman » Sun Sep 15, 2019 12:04 pm
I went to a local building supplier (they were on Rockwool's list) and asked for RW3 as that's what I wanted. I can't remember if they had it in stock or they got it for me, but it wasn't a difficult process!
I may have missed something in the earlier discussions, but I'm not sure why you are getting weights to work out density etc.
Why not just ring, or better still call if it's not too far, and ask for RW3 (if that's what you want) in the thickness you require?
You can go on to Rockwool's site and find dealers by postcode if you want to try other companies closer to you.
https://www.rockwool.co.uk/about/stockist-finder/
Kwackman
Postby Martin Walker » Sun Sep 15, 2019 12:57 pm
Luke W wrote:From what I remember they do. Around here they're a far better company to deal with than Travis Perkins as well, prices are usually a lot better too. Not sure if that's the same everywhere, but I suspect it might be...
I'm pretty sure I got my 45Kg/m3 via Travis Perkins down here in north cornwall, and they even delivered it free of charge!
I'd go for 60Kg/m3 nowadays though if I bought any more.
Postby blinddrew » Sun Sep 15, 2019 12:59 pm
Kwackman wrote:I may have missed something in the earlier discussions, but I'm not sure why you are getting weights to work out density etc.
Selco have Rockwool in stock locally but it has no reference number on the packet - hence establishing the density by weight.
Kwackman wrote:You can go on to Rockwool's site and find dealers by postcode if you want to try other companies closer to you.
Having a shufti now, thanks again. :)
Postby blinddrew » Sun Sep 15, 2019 1:20 pm
I have a product code for the stuff the local places are carrying - but it's not a code that appears on the rockwool website. :headbang:
Email sent to rockwool, will let you know how I get on! :crazy:
Postby Wonks » Sun Sep 15, 2019 1:45 pm
Don't let them pull the rockwool over your eyes! :D
Postby Logarhythm » Sun Sep 15, 2019 1:57 pm
blinddrew wrote:Just under 16kg for the pack so about 35kg/m3.
Not enough irritatingly. Will give Jewson a call on monday but not sure if they sell direct to the public?
Ho hum. Didn't expect this to be easy but thought this bit might be a bit easier! :)
Jewsons definitely do - I cycle past the Exeter branch most days, and they have an enormous sign hung on their fence advertising exactly this.
Logarhythm
Location: On an intergalactic voyage to collect fresh electrons
Postby blinddrew » Sun Sep 15, 2019 4:36 pm
Cheers, will give them a call tomorrow. Should be getting a quote from Selco as well.
P.S. Wonks, I'm ignoring that... ;)
Postby Hugh Robjohns » Sun Sep 15, 2019 4:41 pm
The density of RW3 is 60kg/m3 whereas RWA45 is 45kg/m3. Both are available in various thicknesses from 25 to 100mm and the sheets are generally all 600/1200mm wide/long. Both are class A1 non-combustible, of course.
It's frustrating, but understandable that most building suppliers insist on selling pallet loads, which is a lot of rockwool! And shipping will always be pricey because it is both bulky and heavy... But you can always put the left-overs in the loft! ;-)
For the Studio SOS jobs we generally use Rockwool Sound Insulation Slab packs from Wickes just because it's always in stock and can be bought in small quantities of one or two packs etc...but I'm not sure of its density to be honest... and the website doesn't seem to say.
Postby Sam Spoons » Sun Sep 15, 2019 4:55 pm
Drew is referring to Rockwool Sound Insulation Slabs https://www.selcobw.com/products/insulation/acoustic-insulation/rockwool-sound-insulation-slab-1200-x-600-x-50mm-8-64m
Maybe we get a little too anal about the specifics sometimes :blush:
Postby blinddrew » Sun Sep 15, 2019 5:14 pm
Sam Spoons wrote:Maybe we get a little too anal about the specifics sometimes :blush:
Yeah, I did wonder about that. And then I thought, "but I only want to do this once. And furthermore, if Max says 60kg/m3 is the best compromise, then I'm not going to argue." :D
Postby Music Wolf » Sun Sep 15, 2019 5:38 pm
I'm pretty sure that I got mine from Insulation Express and paid a delivery fee as it was still the cheapest alternative. Just spend a little time thinking through how you will use it so that you only need to order the once.
Music Wolf
Postby blinddrew » Sun Sep 15, 2019 6:02 pm
Music Wolf wrote:I'm pretty sure that I got mine from Insulation Express and paid a delivery fee as it was still the cheapest alternative. Just spend a little time thinking through how you will use it so that you only need to order the once.
They're on my list to call tomorrow, the added complication (because there wasn't enough beforehand) is that my road has a low bridge at both ends, so I need to find out how big their delivery lorries are.
I'm confident on my amounts though.
Probably.
Postby Sam Spoons » Sun Sep 15, 2019 6:15 pm
:thumbup: :thumbup: :thumbup:
That was my take so I went to some trouble to get the RW3 variant. TBF the higher density stuff is easier to work with too.
Postby Hugh Robjohns » Mon Sep 16, 2019 9:22 am
I've just had it confirmed from Rockwool themselves. The 'Sound Insulation Slab' product which you see in Wickes and elsewhere has a density of 35kg/m3 which is okay-ish for broadband absorption panels but not ideal for corner bass traps.
Postby blinddrew » Mon Sep 16, 2019 9:36 am
Funnily enough I've just had an email from them this morning as well. But mine said it was 45kg/m3...
Either way, I've got some phone calls about RW3 to make today. Cheers Hugh.
PreviousNext
