Focusrite ISA430?
Focusrite ISA430?
Postby Arpangel » Fri Oct 18, 2019 9:12 am
I'm still on the look out for some more mic pre's, as my Mike Skeet designed ones are becoming very flakey.
I've always liked Focusrite stuff, the build and sound is spot on for me. Someone mentioned the ISA430 in another thread, looks good, as I really could use a compressor too.
But I need stereo, I just looked at the Focusrite website, looks like the 430 has been discontinued anyway, so I was looking at the Two, but no built in compressor, an all in one channel strip kind of thing would be good, but even if the 430 was still available I'd have to link two of them, the best part of four grand! :(
The good thing about the Mike Skeet unit is that it has built in M+S decoding, a channel strip and mic pre with this feature would be great, but maybe I'm asking a bit too much?
Re: Focusrite ISA430?
Postby Sam Spoons » Fri Oct 18, 2019 10:00 am
Could a good tech rebuild your Mike Skeet preamps or are there impossible to source components in the design?
Postby The Elf » Fri Oct 18, 2019 10:38 am
Ahem... Liquid Channel... Ahem... :shh:
Postby Arpangel » Sat Oct 19, 2019 8:32 am
The build quality of the Mike Skeet preamp is quite crude, I've already had it apart and reseated boards. It needs a rebuild, with some mechanical revisions. I'm not sure it's worth it.
I forgot about the Liquid Channel, but don't want to get into all that digital jiggery pokery.
I'll probably get one of those basic two channel Focusrite jobs, and try and keep the Skeet going for as long as I can. I'm open to other designs, from different manufacturers, but it's a mine field.
Postby The Elf » Sat Oct 19, 2019 8:50 am
Arpangel wrote:I forgot about the Liquid Channel, but don't want to get into all that digital jiggery pokery.
Not sure what you mean. You can use it as an analogue pre and not even connect the digital side. I've never wanted another pre since I got mine - buy once, use forever.
Postby Arpangel » Sat Oct 19, 2019 9:00 am
I'm going to have a rethink, I'll need two liquid channels, plus, they don't make them anymore. Although the 430 is still being advertised on some sites, but two of those is a bit OTT, I need a one box solution, but I don't think I'm going to find it, at any price.
Postby Sam Spoons » Sat Oct 19, 2019 9:24 am
I seem to recall you saying on another thread how much you love the Mike Skeet pre's. If so, and nothing else does the job as well, I'd say a 'proper' rebuild was still worth considering.
Postby Arpangel » Sat Oct 19, 2019 10:31 am
Sam Spoons wrote:I seem to recall you saying on another thread how much you love the Mike Skeet pre's. If so, and nothing else does the job as well, I'd say a 'proper' rebuild was still worth considering.
Yes, the Skeet job is perfect, I wish I'd got two! It's terrible as I know a few actually got thrown away before or when he died :shock:
OK, I'll get it looked at, but in the meantime I need something to use, I may get one of those Focusrite 2's to bridge the gap.
Postby Urthlupe » Wed Oct 23, 2019 9:47 am
Lunchbox - configure your own channelstrips?
Loopy
Urthlupe
Postby Arpangel » Thu Oct 24, 2019 10:16 am
Urthlupe wrote:Lunchbox - configure your own channelstrips?
Loopy
Good idea, and the only reason I can justify for getting 500.
Postby The Elf » Thu Oct 24, 2019 10:27 am
My LCs are flight-cased to go everywhere with me. If you want to give them a try I can drop 'em by for a few days. The offer is there if you fancy it.
Postby Arpangel » Thu Oct 24, 2019 11:11 am
The Elf wrote:My LCs are flight-cased to go everywhere with me. If you want to give them a try I can drop 'em by for a few days. The offer is there if you fancy it.
That's amazing Elf! many thanks! I'll take you up on it, maybe we can sort something out via pm's, and I'll send you my email.
Postby nathanscribe » Mon Nov 04, 2019 1:43 pm
Just to chuck another box into the fray, there's the UA 4-710d, which is a 4-channel unit with compressors: https://www.uaudio.com/hardware/4-710d.html
Not really a channel strip but you do get the dynamics at least.
nathanscribe
Postby MOF » Mon Nov 04, 2019 2:20 pm
Have you thought about the ISA 2 plus the latest software emulation of the console for its eq and compressors? The two together will still be cheaper than the ISA 430.
https://focusrite.com/news/introducing- ... -focusrite
MOF
Postby Arpangel » Tue Nov 05, 2019 8:41 am
MOF wrote:Have you thought about the ISA 2 plus the latest software emulation of the console for its eq and compressors? The two together will still be cheaper than the ISA 430.
The ISA2 is standing by, it'll be bought for sure, as the most important thing is to replace the preamp, I'm not really bothered about the rest right now.
Preamps are rather strange, my Skeet one performs extremely well "technically" buckets of gain, with no discernible noise, and incredibly high headroom, but, I can't comment on the sound, it doesn't really have one, and if a mic amp does its job well that's how it should be, and comparing similar engineered ones is a bit boring, there's very little difference, if any in the actual sound. As has been said on this forum many times, changing the microphone will make much more difference than changing the preamp.
