Are high quality monitors suitable for relaxed listening?
Re: Are high quality monitors suitable for relaxed listening?
Postby ef37a » Mon Nov 18, 2019 5:52 pm
Arpangel wrote:IMO there is no such thing as a neutral, or uncloroured speaker, and every speaker has "a sound" some more than others.
If a piece of music sounds great on one speaker but a bit bad on another, then which is right? and by saying "bad" who's bad would that be?
Some of my Velvet Underground recordings are amazingly bad, and sound bad on everything, my stereo, monitors, car, Bluetooth speakers, crappy music centres, and a lot of those speakers are awful, but they still let me know that it's a rough recording. And better (whatever that is) recordings sound better on all these speakers too.
So do we actually need a £10,000 monitor to make technical/quality judgements? I'm not sure?
One theory is that the bigger the window you have the more you can see, but I don't need a wall sized window in a mansion to see that it's raining outside. An "OK" speaker will tell you the essentials, the rest is a luxury that's nice to have, but not absolutely necessary.
Great records of all time have been made on all sorts of speakers, countless approaches to this whole thing, which tends to make me think it's pointless laying down rules on monitoring, it's as personal as choosing any instrument, we all have our own preferences and ideas about what things should sound like.
People I know who have made and are making music, a couple who are professional/successful, and some like me, essentially amature. There are Tannoy Little Reds in two cases, me and my 45 yo KEF"s, a pair of Alesis Monitor 1's, some Heybrook hi-fI speakers, AR Red Box, Proac Studio 1's. Quite a mixture of speakers, but I don't even think about them when I go to these people's places, they are just there.
And whether recording or relaxing, I don't have speakers for those two seperate things, it's never been an issue.
Sorry, cannot agree friend. Reading Hi Fi News reviews from the 70s/early 80s high quality speakers were tested against real sounds such as instruments in the room, jangling keys and both male and female speech. Very often the benchmark of low colouration and accuracy was the Quad ELS. Thus, the test was not for a 'nice' speaker but one that reproduced reality.
Then it all went Ts U and silly.
Such tests are not done today (why?) but it is very common to read, when Phil or Hugh are testing the latest £xxxx wonder (its a tough job but...!) that the top end monitors compare very closely to the already very high quality incumbents.
There is the logical conclusion that 'perfect' speakers would all sound exactly the same and would reproduce ALL sounds with equal fidelity regardless of frequency or SPL.
Not there yet but if you have enough mooolar, getting bloody close!
Postby ef37a » Mon Nov 18, 2019 6:00 pm
The Bunk wrote:Thanks Dave, that's helpful and useful to know.
Fortunately, things aren't that tight so I can carry on!! I hadn't thought about the amp possibly doing more. I just happened to notice a while back that when I was doing lots of home recording, my elec bills went up. So I'd have a guitar FX pedal, guitar amp, computer, monitors and quite possibly hi-fi amp (for A/B purposes) all on at the same time.
Heh! I f you REALLY want to save money, don't use batteries in the pedal! Very expensive way to buy electricity. You could use rechargeables and solar power!
Someone just leaving the bog light on probably accounts for the price increase rather than your musical endevours.
Postby Hugh Robjohns » Mon Nov 18, 2019 6:17 pm
Tim Gillett wrote:...it could be a variant on the sometime microphone debate where it's claimed using calibrated measurement mics results in otherwise wonderful acoustic performances being turned into "cold, clinical" recorded performances. Again a fundamental failure to understand that fidelity is... fidelity. What more can one say?
The 'what more to say' is probably that recording music is -- for most of us, most of the time -- a personal art form.
In the painting art world, some artists create photo-realistic images, whereas others produce impressionistic watercolours. For the same source inspiration you'd get totally different 'user experiences'. Would you say one was 'right' and the other 'wrong'? No, of course not!
So while audio recording fidelity -- genuine, accurate, completely transparent fidelity -- is appropriate for some applications, it's clearly not so for all. Often some intended, pleasing colourations or distortions -- whether from microphone choice, or placement, or through signal processing -- may well add positively to the musical experience or allow the recording artists/producer/engineer to create the kind of sound they want to deliver as the 'user experience'.
If someone feels a technically accurate mic sounds 'cold and clinical' to them, and doesn't deliver the kind of sound they want to hear, that's an entirely valid opinion in my book. I don't see the benefit in sneering at that view... Their art is not your art...
Postby ef37a » Mon Nov 18, 2019 6:39 pm
Totally agree Hugh but I am also sure that you will agree with me that a monitoring system has to be as above reproach and accurate as possible?
A speaker that flatters some sources but is dull or strident on others cannot produce consistent work.
Postby Hugh Robjohns » Mon Nov 18, 2019 7:27 pm
ef37a wrote:Totally agree Hugh but I am also sure that you will agree with me that a monitoring system has to be as above reproach and accurate as possible?
Quite so. That is the definition of a monitor speaker, surely?
Indeed. It's why I've always laughed at the notion that a certain 'monitor speaker' is great for rock or classical etc...
Postby Tim Gillett » Mon Nov 18, 2019 7:54 pm
. We know that accurate gear will not change a performance into "cold and clinical" or into anything else for that matter. We also know the difference between fidelity which is objective, and human preference which varies somewhat. I didn't sneer at personal preference. It just wasn't the topic I spoke to, which was fidelity.
Tim Gillett
Postby John Willett » Tue Nov 19, 2019 12:46 am
Tim Gillett wrote:Interesting. Could you supply a link please John?
It's HERE - it's 116 pages and very long - but good reading.
The author let me do a reprint of his comments and reasons on the ME-Geithain monitors - and that's here
The original post for the bulk of the above is post # 2305 on this page (which also mentions the "other loudspeaker" I mentioned). The other quotes (in boxes) are from other posts he made - he did see the final thing before publication, gave his blessing and supplied a photo of his studio to go with it.
But the whole thread is good reading and he tested all the monitors properly, using them for mixing and mastering and wrote about it all as he went along.
John Willett
Postby Tim Gillett » Tue Nov 19, 2019 8:54 pm
ef37a wrote:
...There is the logical conclusion that 'perfect' speakers would all sound exactly the same and would reproduce ALL sounds with equal fidelity regardless of frequency or SPL.
I agree Dave, and if all sounded the same then none would be any more "tiring" to listen to the next. Speakers these days though while more accurate than ever, will probably never reach the accuracy of mics. Speakers have a much harder job to do. They don't merely respond passively to air waves but have to create them and at high SPLs. Very difficult task for their design and manufacture.
Tim Gillett
Postby Chump » Wed Nov 20, 2019 12:43 am
I mix on studio monitors but I've got an old NAD 3020 amp based setup in the living room that gives a definite colouration to the sound (I've tried the amp with a few different speaker / room combinations, and its definitely the amp that gives the colouration). Sounds absolutely nothing like my monitors, but is weirdly flattering to pretty much any material I throw at it, and with a beer I think I might prefer it to my monitors. Useless for mixing though.
Chump
Postby Tim Gillett » Wed Nov 20, 2019 2:55 am
Unless the NAD is faulty, is driving speakers it's not designed for or is pushed beyond its limits, it's most unlikely to be the weak link in the setup. Is it possible what flatters the sound is the beer? Not just for you but for all of us...
Tim Gillett
Postby N i g e l » Wed Nov 20, 2019 3:37 am
Tim Gillett wrote: Is it possible what flatters the sound is the beer? Not just for you but for all of us...
cheapest hifi upgrade is a glass of wine/beer !
Alcohol takes the edge off the real time processing ability required to detect a fake soundstage from the real thing.
What i cant get is Studio engineering v HiFi, surely the same thing with a common goal, yet they are two differnt camps.
Active monitor speakers - putting the electronics in a pressure modulated enclosure - thats like having someone tap your valves with a biro in time with the music ???
Postby Luke W » Wed Nov 20, 2019 8:40 am
N i g e l wrote:
Audio engineers use speakers to listen to their music, and Hi-Fi enthusiasts use music to listen to their speakers.
Or something like that, I'm sure I'm not quoting it perfectly...
Luke W
Techie / Musician Of Sorts
Postby ef37a » Wed Nov 20, 2019 10:07 am
Tim Gillett wrote:Unless the NAD is faulty, is driving speakers it's not designed for or is pushed beyond its limits, it's most unlikely to be the weak link in the setup. Is it possible what flatters the sound is the beer? Not just for you but for all of us...
I USED to be of the opinion Tim that power amplifiers of competent design* were subjectively 'perfect' and did not add 'colour' to a signal.
After reading Self on amps I realized that unless the output resistance is extremely low, some loudspeakers with wide variations of impedance could show response iregularities especially if they dipped below 4R.
I still think such an effect would be very subtle and speaker responses are pretty wild, even if driven from a truly near short. Then the marrying up of such a crap amp with a mad Z speaker is quite unlikely?
*You could of course argue that an amplifier that did not have a near zero OPZ was not a competent design anyway?
Postby Arpangel » Wed Nov 20, 2019 10:20 am
Chump wrote:I mix on studio monitors but I've got an old NAD 3020 amp based setup in the living room that gives a definite colouration to the sound (I've tried the amp with a few different speaker / room combinations, and its definitely the amp that gives the colouration). Sounds absolutely nothing like my monitors, but is weirdly flattering to pretty much any material I throw at it, and with a beer I think I might prefer it to my monitors. Useless for mixing though.
Chump. I'm not a hi-fI freak, or an obsessive about this subject in any way, but that NAD is absolutely awful, god knows how it became a fave of the hi-fI community.
It's so bad, the top end is searing, a friend had one and he's almost deaf, and even he couldn't stand it. We used to laugh, it was so harsh and toppy. It wasn't a fault, they're all like it.
It will make the smoothest dullest speaker sound like an NS10 on steroids.
It was a product of that obsession with detail in the early 80's, they thought that just by emphasising the upper mid and top it was all you had to do, at the expense of everything else.
Postby Sam Spoons » Wed Nov 20, 2019 11:40 am
I used to believe that a hifi amp was the last thing to colour the sound. Back in the day I had a Sansui 222 turntable, Celestion Dittion 15 speakers, and a Leak Stereo 30 amp. I upgraded the amp to a used Sugden A48 (one of the orange, silver and brown ones which I still have) and even my wife heard the difference immediately. It was night and day.
PreviousNext
