Pedalboard Day!
Re: Pedalboard Day!
Postby The Elf » Tue Jan 14, 2020 3:36 pm
Personally I would avoid any PSU that itself has a PSU. Better to just have a mains plug.
The SoundLab 450 I use goes for 10 or 20 quid on eBay and would do the job from what I can see.
Re: Pedalboard Day!
Postby Hugh Robjohns » Tue Jan 14, 2020 3:45 pm
I feel the need for a further explanation.
The cheapest way to make a guitar pedal power supply is to have one power supply, with a single mains transformer and a single DC regulator, converting from the incoming mains down to 9V DC (or whatever), and then make that power rail available at multiple sockets wired in parallel -- effectively daisy-chaining the one supply to every pedal.
The potential problem with that is that if there's a fault in a cable, or a pedal goes phut and shorts the supply, it could take out the whole power supply and stop everything working. And if any pedal dumps noise into the power rail, it gets shared with everything else... not cool!
So the next level up is where the main power supply converts from mains to some convenient intermediate voltage (via a single mains transformer again), and then that is further processed to provide the required individual 9V supplies (or whatever) via several independent regulating stages, one for each physical output.
This kind of PSU will usually claim to have 'independent outputs' -- but is basically just means that each output is electrically buffered, so a fault on one won't affect all the others, and hopefully noise from one wont get passed back through to the others....
However... all of the outputs share the same ground reference so plugging all your pedals into it can potentially result in ground-loops between them, with all the corresponding hums and buzzes... (particularly when the pedal line up includes digital effects).
So this is the kind of device you're currently considering. It can work perfectly well, and clearly some here have found that. But you should be aware of its limitations and the potential for problems.
The most expensive -- but proper engineering -- solution for a pedal power supply is either to have lots of separate mains transformers, or (more usually) a single mains transformer but with lots of separate secondary (output) windings.
Each of these separate secondary windings (or separate mains transformers) is connected to its own separate regulating circuitry to generate completely separate, isolated, independent power outputs. In this way, none of the power outlets share a common ground, so there can be no ground-loops between pedals. Guaranteed to be completely noise free, regardless of what pedals you're using.
But those transformers (or multi-secondary transformers) are expensive (and heavy). This is why the best pedal PSUs cost £250 rather than £50, but also why they are so much better, in a technical sense.
You can see all the separate secondary winding connections feeding separate independent DC regulator stages clearly in this pic of the inside of the Oktopus: Image
Re: Pedalboard Day!
Postby CS70 » Tue Jan 14, 2020 3:58 pm
One of my two supplies is a FuelTank Chameleon from T-Rex which has isolated outputs and supports a 12/18VC for the occasional odd pedal. Been gigging it heavily for seven or eight years now, always worked a charm.
Here it's fairly common to find units used and often they can be had at a bargain - if you find one, can't recommend it enough, it's buy once and forget.
Re: Pedalboard Day!
Postby Sam Spoons » Tue Jan 14, 2020 4:16 pm
Accepted that 'doing it properly' is always the best solution but if you have a non-isolated pedal power supply you could break a ground loop with a custom signal cable with the screen disconnected at one end. How effective that would be I don't know but worth a try?
Re: Pedalboard Day!
Postby Luke W » Tue Jan 14, 2020 4:41 pm
CS70 wrote:One of my two supplies is a FuelTank Chameleon from T-Rex which has isolated outputs and supports a 12/18VC for the occasional odd pedal. Been gigging it heavily for seven or eight years now, always worked a charm.
I've got a Chameleon on two of my boards as well, they've been great bits of kit. T-Rex also make a couple of smaller/cheaper supplies, the Junior comes to mind.
Luke W
Re: Pedalboard Day!
Postby ore_terra » Tue Jan 14, 2020 5:01 pm
Garretendi, you don't need a super powerful PSU for those pedals as none of them is a real power sucker despite what the specs say.
also, the TU-3 itself can act as PSU for the other pedals getting one of theseImage
I'd give it a go if you cant spend much in a PSU. or maybe feeding all except the Nova Modulator from the TU-3 and this one with its own PSU.
regarding cheap-ish PSU, I've used an Artec one in the past that still works, and I own a JOYO that works very well (however the one I use live is a 250 quid Voodoo Labs :lol: :lol: )
ore_terra
Re: Pedalboard Day!
Postby Stratman57 » Tue Jan 14, 2020 5:04 pm
I've got one of these.
https://www.amazon.co.uk/gp/aw/d/B075ZT7B5F/ref=ppx_yo_mob_b_inactive_ship_o0_img?ie=UTF8&psc=1
It may be cheap, but it powers my pedal board noiselessly. It's a mix of analogue and digital pedals. (Cry Baby wah, tuner, compressor, Joyo overdrive, Marshall regenerator, Boss SY-1 or EH Mel9 and a Boss RE20 echo pedal).
Unfortunately it isn't powerful enough for the Mooer Baby Bomb micro amp.
The only problems I have with the pedal board are the velcro doesn't stick to some of the pedals so they tend to fall off the board, and the rubber feet on the board came off when I tried sliding it across the floor. :headbang:
Regards, Simon.
Stratman57
Re: Pedalboard Day!
Postby Sam Spoons » Tue Jan 14, 2020 5:28 pm
Re Velcro, I used to have the same problem, completely solved it by using Velcro branded Velcro from Toolstation. It's essential to clean the surface with Isopropol Alcohol or something similar to be sure it will stick, the rubber base/feet of pedals probably has some kind of release agent on the surface but anything slightly greasy will stop the velcro sticking securely.
Re: Pedalboard Day!
Postby ore_terra » Tue Jan 14, 2020 5:46 pm
3M velcro is also great
ore_terra
Re: Pedalboard Day!
Postby MOF » Tue Jan 14, 2020 6:11 pm
You could sell all those pedals and get one mains powered multi-effects device. :D
MOF
Re: Pedalboard Day!
Postby ManFromGlass » Tue Jan 14, 2020 6:51 pm
I’ve tried a few of them and will still use them, but there is still something about the immediacy of a pedal for me, even the ones that can’t decide if they should be on the floor or higher because they are synth-like and knobs must be tweaked.
Re: Pedalboard Day!
Postby Stratman57 » Tue Jan 14, 2020 7:01 pm
I have a Line 6 Firehawk multiFX for when we're practising in the keyboard players utility room on headphones during the winter months.
His outbuilding is not insulated.
Regards, Simon.
Stratman57
Re: Pedalboard Day!
Postby The Elf » Tue Jan 14, 2020 7:52 pm
MOF wrote:You could sell all those pedals and get one mains powered multi-effects device. :D
I think we've been there!
But if the OP re-considers I can whole-heartedly recommend the Digitech pedals. I have a clutch of these - the RP50, RP55, RP500 and RP1000 - all are excellent in their own way.
I picked each of these up for less than the price of that Gokko pedalboard alone! :D
But I suspect I know the response! ;) :lol:
Re: Pedalboard Day!
Postby garrettendi » Tue Jan 14, 2020 8:12 pm
The Elf wrote:But I suspect I know the response! ;) :lol:
Am I that predictable???
I’ve used multi effects in the past and while I appreciate their convenience, I like my current effects too much!
garrettendi
"I mean, Led Zeppelin didn't write tunes that everyone liked. They left that to the Bee Gees"Wayne Campbell (Wayne's World)
Re: Pedalboard Day!
Postby MOF » Tue Jan 14, 2020 8:38 pm
I’m not a guitarist but I suppose that, given that it’s common knowledge you can never have enough guitars, you can never have enough effects pedals either. :lol:
MOF
PreviousNext
