Windows 7 no longer supported....
Re: Windows 7 no longer supported....
Postby merlyn » Thu Jan 16, 2020 6:21 pm
With Reaper you would install the Linux version of Reaper to the Linux partition.
Adobe products are not supported on Linux unfortunately, so that is likely a deal breaker for you.
merlyn
Postby Marbury » Thu Jan 16, 2020 6:36 pm
merlyn wrote:Adobe products are not supported on Linux unfortunately, so that is likely a deal breaker for you.
In that case I will stick with the free antivirus for the time being.
Marbury
Postby wireman » Fri Jan 17, 2020 8:18 pm
The big risk would be a remotely accessible exploit in a service that your computer runs. I guess home routers all have a firewall which is good. Shieldsup used to be a good test to run to see how open your computer is.
By the way I just got a W10 laptop from work (have not used it before) and I still can't work out how to get a volume control on the taskbar so this is going to be a learning curve.
wireman
Postby James Perrett » Fri Jan 17, 2020 9:54 pm
wireman wrote:By the way I just got a W10 laptop from work (have not used it before) and I still can't work out how to get a volume control on the taskbar so this is going to be a learning curve.
Here I have a speaker icon in the bottom right hand corner. Click on it to show the volume control.
Postby DGL. » Fri Jan 17, 2020 10:25 pm
If it's not present at all then make sure it is turned on in the "turn system icon on or off" in settings, if you then want it to be permanently on teh task bar (without clicking the "more"/up button (it's probably not called that) then either drag it from the "more" menu to the task bar or use the "select which icons appear on the taskbar" settings page to have it on view permanently.
DGL.
Postby wireman » Sun Jan 19, 2020 5:22 pm
I already checked the taskbar settings and that it was enabled within the system icons, other icons enabled in those settings do show. I don't have a more menu, at least not something like what I had in Windows 7. I even resorted to asking my son who has used Windows 10 for a while now, he has the icon.
W10 will quite happily show the volume control/mixer and put the icon on the left of the taskbar when that is running.
wireman
Postby Watchmaker » Sun Jan 19, 2020 6:25 pm
Much ado about nothing.
Win7 is a decent OS. Win10 is a rapacious data whore with some enhanced capability and is a decent, not amazing or great, OS.
The odds that your Win7 machine will be a target for any miscreants is minimal, especially if you use your Win10 machine to surf porn. Then you can judge how much better it is for security. Flatly, every OS is relatively easy to hack, but the overwhelming majority are simply not worth the time. Most "hacks" are akin to a priest and a virgin walking into a biker bar and asking to "be served."
Another quibble from me: most of the win10 Acolytes I've run across are perfectly comfortable having every key stroke recorded by the NSA. I don't share that level of trust, so Win10 is a major concern for me and I've gone to extreme lengths to moderate its behaviors.
As in all things: caveat emptor.
Watchmaker
Postby CS70 » Mon Jan 20, 2020 4:36 pm
Watchmaker wrote:The odds that your Win7 machine will be a target for any miscreants is minimal, especially if you use your Win10 machine to surf porn.
Agreed, but by the same meter, who in NSA can be possibly interested in our keystrokes? :D
Postby Hugh Robjohns » Mon Jan 20, 2020 5:06 pm
If the NSA were genuinely interested in your typings, it really wouldn't matter which OS you decide to use...
Postby Eddy Deegan » Mon Jan 20, 2020 5:08 pm
Watchmaker wrote: most of the win10 Acolytes I've run across are perfectly comfortable having every key stroke recorded by the NSA. I don't share that level of trust, so Win10 is a major concern for me and I've gone to extreme lengths to moderate its behaviors.
Err, you don't have to go to extreme lengths. What you do have to do is spend an annoying half hour or so meticulously going through every privacy setting and disabling them as appropriate.
For typing, just disable the "Inking & typing personalisation" switch in the privacy settings.
Some of my works.
Postby Eddy Deegan » Mon Jan 20, 2020 5:09 pm
Hugh Robjohns wrote:If the NSA were genuinely interested in your typings, it really wouldn't matter which OS you decide to use...
Spot on, Hugh.
Some of my works.
Postby Pete Kaine » Mon Jan 27, 2020 10:45 am
For those that prefer the shotgun approach.
https://www.oo-software.com/en/shutup10
Pete Kaine
Postby The Elf » Mon Jan 27, 2020 1:53 pm
Pete Kaine wrote:For those that prefer the shotgun approach.
:thumbup: :clap:
Postby Marbury » Mon Feb 03, 2020 7:08 pm
A friend had a nightmare getting my old windows 7 sd drive updated with 10 as the new pc motherboard it is going into is usb 3, and the computer that it came out of is usb 2. tried everything to no avail as it won’t install onto the drive because that drive was installed on a usb 2 motherboard.
Marbury
Postby Pete Kaine » Tue Feb 04, 2020 12:01 pm
The drive is connected over SATA through?
So, it's not installing because it's causing BSOD's due to the wrong USB driver found in the old install?
Try the following: Disable the USB3 headers in BIOS, get into windows, update chipset and everything else relevent.
Now find the correct USB driver, install, reboot, enable USB 3, cross fingers.
Pete Kaine
PreviousNext
