Because it may not be installing into the place where Reaper is looking. You are going to have to be methodical about this and work through it carefully.Marbury wrote:Even more worrying is it's the same after a system restore from a few days ago. I did open Reaper and see the Omnisphere was up to date but again, I open a different saved project and it was telling me again it needed updating. I then opened the previous project that showed it was up to date and you guessed it, it now shows it needs updating. How can this be when ALL projects are universally set to the same paths (telling Reaper where to look for vsts etc) in preferences ?
Again... this has nothing to do with Reaper! It doesn't matter where Reaper is looking for projects. Omnisphere has its own folders and you need to sort those out.
