Can an input signal damage a switched off audio device?
Postby forumuser935193 » Thu Sep 17, 2020 3:24 pm
In my home studio, I often leave some audio equipment powered off when I do not need it, for example, effects units, an analog compressor, an analog mixing console, or an external headphone amplifier. However, due to the cabling and signal routing, I may still send some healthy line-level signals to the inputs. Can this cause damage?
The question is rather precautionary, I have not yet come across a problem caused by it.
Many thanks in advance!
Ron
forumuser935193
Re: Can an input signal damage a switched off audio device?
Postby Martin Walker » Thu Sep 17, 2020 4:21 pm
Hi Ron, and welcome to the SOS Forums! 8-)
I think it's highly unlikely that you'll do any damage applying healthy line-level signals to gear that's powered down.
Always happy to be proved wrong, but I haven't heard even anecdotal evidence of this occurring during the last 50 years ;)
Just don't try plugging in any AC mains voltage into your line inputs :beamup:
Postby Hugh Robjohns » Thu Sep 17, 2020 4:25 pm
No. Provided the signals you're sending are within the normal operating levels the unit would expect anyway, it won't be damaged if turned off at the time.
Postby forumuser935193 » Thu Sep 17, 2020 4:28 pm
Martin and Hugh,
Many thanks for your super-fast replies! :D That is reassuring to know, then I am a bit relieved.
Best,
Ron
forumuser935193
