Recreating an old vinyl sound
Postby Panda » Mon Oct 12, 2020 9:09 pm
Hi!
Long time since my last post here! So I have a question which might be a little odd. We recorded an album with my band, an acoustic ensemble. We decided to put one tune on the CD as a hidden track, and to make that track sound as if it was taken from a very old record.
This is the kind of sound we're trying to recreate:
https://www.youtube.com/watch?v=TFSsBuPCzY8
The mix is in ProTools. Question is: how to turn a decent sounding recording into something like this?
Thanks for your input!
Panda
Re: Recreating an old vinyl sound
Postby RichardT » Mon Oct 12, 2020 9:25 pm
Panda wrote:Hi!
I use the Vinyl plugin from Izotope.
RichardT
Postby James Perrett » Mon Oct 12, 2020 9:29 pm
Which happens to be free at the moment.
Postby Panda » Mon Oct 12, 2020 9:53 pm
Ok, thanks! I checked out the trailer (I don't have PT here at home anyway). Is it geared to really go all the way like in the tune I linked to in my post?
Panda
Postby RichardT » Mon Oct 12, 2020 9:59 pm
Panda wrote:Ok, thanks! I checked out the trailer (I don't have PT here at home anyway). Is it geared to really go all the way like in the tune I linked to in my post?
Best thing is to give it a go!
RichardT
Postby Panda » Mon Oct 12, 2020 10:02 pm
Fair enough, let's see what happens!
Still, I'd be interested to hear other ways to get there if anyone knows of any!
Panda
Postby desmond » Mon Oct 12, 2020 10:04 pm
Make it mono, reduce the frequency range (ie roll off the highs and lows), maybe compress a little, maybe distort a little, make the pitch be slightly unstable perhaps, and add a looped vinyl noise/crackle sample...
desmond
Postby Vox Gnus » Mon Oct 12, 2020 10:08 pm
No idea what budget you're considering, but Audioease Speakerphone is fantastic for this sort of thing (and much more). It's expensive, and getting a bit old, but there isn't much that compares. Check out the demos and see if it fits your needs.
https://www.audioease.com/speakerphone/
Vox Gnus
Postby Panda » Mon Oct 12, 2020 10:10 pm
Vox Gnus wrote:No idea what budget you're considering, but Audioease Speakerphone is fantastic for this sort of thing (and much more). It's expensive, and getting a bit old, but there isn't much that compares. Check out the demos and see if it fits your needs.
Interesting, but I doubt the studio has this and for sure they're not going to buy it for just this one tune. I know I'm not :-)
Panda
Postby CS70 » Mon Oct 12, 2020 10:11 pm
As noise and other nasties go, if I remember well it can do much worse. :D
For the general sound, not sure, worst case you can do the lot simply by following Desmond's ideas.
Postby blinddrew » Mon Oct 12, 2020 10:22 pm
RichardT wrote:
Panda wrote:Hi!
Yep, that sounds like exactly the kind of effect you can get from Vinyl if you crank the settings right the way up. And if you need any more then Desmond's toolkit above should be able to take you right back to wax-cylinder territory. ;)
Postby Tim Gillett » Mon Oct 12, 2020 10:28 pm
Yes that asking price seems about right.
Tim Gillett
Postby MOF » Mon Oct 12, 2020 11:12 pm
https://www.waves.com/plugins/abbey-roa ... gL70PD_BwE
I own it and apart from, in your case, having to cut a bit more bass and treble before the plugin it should work well; currently £29.99.
MOF
Postby Martin Walker » Tue Oct 13, 2020 12:12 am
Another vote for iZotope Vinyl, which as far as I remember has ALWAYS been free, and can add effects ranging from subtle to extreme.
It's particularly good at adding vinyl clicks, pops, dust, scratches & warps, so as others have said, I doubt that you'll need anything else. Just dial in your desired decade for EQ, your chosen vinyl speed, and then tweak the rest to taste.
If I recall correctly, you can also download various presets from the iZotope web site for it, to simulate various desired results & save you fiddling about too much ;)
https://www.izotope.com/en/products/vinyl.html
Postby Mike Stranks » Tue Oct 13, 2020 9:08 am
Another very occasional iZotope Vinyl user here. :thumbup:
