Last month, I replaced the stock control plate with one designed for a standard Telecaster with two single-coil pickups. The solderless installation made the upgrade easy. For me it just "dropped in." (see before-after picture)
It came with Bourns pots mounted to a printed circuit board with Treble Bleed to keep the brilliance from getting "muddier" as the volume is dialed back.
It has three mini toggle switches instead of the stock 3-way blade switch. Two of the switches are on-off-on and control each pickup by turning it Off or On (in either normal-phase or reverse phase.) The third (middle) on-on switch puts the pickups in either parallel or series circuit. The switch layout is simple and intuitive. The end result is an instrument that goes beyond the three stock pickup tones.
After the upgrade, I have six pickup tones. I still have the stock three sounds, but the extra three sounds are distinct and useful. Putting both pickups in series (and in-phase) gives me a strong jazz-like humbucker sounding tone, something that I could not get from my stock Telecaster. And hearing those additional two new intense and more intense out-of-phase country twang tones (switched in either parallel and series) gave me goosebumps. These are glass-shattering tones that can punch out windows at 30 paces.
I'm happy with the upgrade because it gives me three additional pickup tones.
