Hopefully somebody might know the answer to this...
I have approx. 15 choir members submitting audio files each week, recorded to a variety of mobile devices/laptop/desktop computers. Usual covid thing.
Each week there's a minimum of two audio files sent per person, however this often increases with multiple takes or different voice parts etc. So quite a few files coming to me by various methods and collating takes a bit of time.
I'd like a way of creating a shared folder that senders can drop files into BUT not view (play/download) each others. AFAIK this isn't something I can do on the usual cloud storage providers (Google, Dropbox, Box) nor can I do using the file sharing sites that create a download link (WeTransfer). For efficiency I just want the files dumped into a single folder that only I have access to.
Is there a way?
File sharing
• Page 1 of 2 • 1, 2
Re: File sharing
What I can do... is create a shared folder per member on G Drive.... but retrieving the files out of each is more annoying than having one folder for everyone.
Humf - Regular
Re: File sharing
I don’t have time this second to look, but maybe Microsoft Onedrive?
resistorman - Frequent Poster
Re: File sharing
Humf wrote:What I can do... is create a shared folder per member on G Drive.... but retrieving the files out of each is more annoying than having one folder for everyone.
Do you have a Google Drive folder on your local computer? If so, you could use a search for new files to pick them all up at once and then move them to your working folder.
James Perrett - Moderator
Re: File sharing
Don't know if this would work, but Drop Box has an option to "Request Files", which seems to put files from people into a folder only you can access.
See https://help.dropbox.com/files-folders/ ... le-request
Kwackman - Frequent Poster (Level2)
Re: File sharing
resistorman wrote:I don’t have time this second to look, but maybe Microsoft Onedrive?
Admittedly I haven't checked OneDrive. But I'm very reluctant to use anything MS related. Rightly or wrongly I've developed an allergy! Beggars can't be choosers though I guess...
Humf - Regular
Re: File sharing
James Perrett wrote:Humf wrote:What I can do... is create a shared folder per member on G Drive.... but retrieving the files out of each is more annoying than having one folder for everyone.
Only use the browser version but that's an idea ...
Although I have just remembered that the 'shared' tab on the browser version does list recently shared files so then it would be a drag and drop in working folder. That could work.
Humf - Regular
Re: File sharing
Kwackman wrote:Don't know if this would work, but Drop Box has an option to "Request Files", which seems to put files from people into a folder only you can access.
Cool thanks. If it works then that could be precisely what I'm after
I'll have an explore...
Humf - Regular
Re: File sharing
I believe this is how to do what you want to do with Google Drive
https://support.google.com/drive/thread/8347046
- rockydennis
- Poster
Re: File sharing
Humf wrote:Kwackman wrote:Don't know if this would work, but Drop Box has an option to "Request Files", which seems to put files from people into a folder only you can access.
Cool thanks. If it works then that could be precisely what I'm after![]()
That works a treat, thank you.
But my preference is for Google as that's what I use mainly and have tons of space with. So let's see if i can get that to work now!
Humf - Regular
Re: File sharing
Humf wrote:Hopefully somebody might know the answer to this...
Is there a way?
I don't know - but have a think about whether it really matters if people can see or download eachother's files. These people do sing together...
- RichardT
- Frequent Poster
Re: File sharing
rockydennis wrote:I believe this is how to do what you want to do with Google Drive
Thanks for this. Useful to know that it is possible. But the steps required by the collaborators introduces additional potential pitfalls. Some are doing well to record and I think any extra hurdles make this a less elegant solution than the Dropbox method.
Humf - Regular
Re: File sharing
RichardT wrote:Humf wrote:Hopefully somebody might know the answer to this...
Is there a way?
Yep - generally people would be ok. But perhaps one or two, maybe more, I think would be nervous. I'm thinking all or nothing, so if some opt out then it kills the idea for me.
Humf - Regular
Re: File sharing
I use Google Drive for some stuff, but Dropbox is much easier. I do this kind of stuff all the time - a shared folder for everyone and Bob's your auntie's husband.
The Elf - Jedi Poster
Re: File sharing
You could use Google Classroom - all submitted files will be in an assignments folder but no one will see the other participants work.
Or Bandlab education; more individual downloads rather than a group folder here so not solving one problem but you can have a common guide track and audio will be recorded in the format you've specified for the project. By the sound of it you might need to do a bit of coaching for people to learn how to use it though so this may not be an attractive proposal.
Both free
Both free
Murray B - Regular
