manwilde wrote:I can´t tell how many times I´ve felt the same about this place... Truly a treasure, both in information wealth and civil discourse
Yeah it has got the lot. Even the humour is incredibly nuanced
Mike Stranks wrote:We all have our own ways of working. For instance, because of my background, I only do the simplest of edits in my DAW; 95%+ of tricky edit work is done in a separate standalone editor.
Mike Stranks wrote:These differences are not wrong, but we can all keep learning and adapting our techniques appropriately. Sometimes a throwaway comment here will make me think, "Of course!" and adopt a new technique because it's simply much more easy and straightforward.
There's only two key questions in the 'how to work' with regard to your existing practices:
* Does it work?
* Is it driving me nuts?
As long as the answers are respectively 'Yes' and 'No' then all is well... If not then come here and ask for some pointers...
Simples...
The Culprit wrote:Think this weekend will mostly be spent finding a decent editing workflow so expect a few bumps if this thread
The Culprit wrote:Mike Stranks wrote:We all have our own ways of working. For instance, because of my background, I only do the simplest of edits in my DAW; 95%+ of tricky edit work is done in a separate standalone editor.
Standalone editor...I take it that's a sampler you're referring to? A wee Akai is certainly on my list of future devices to try![]()
The Culprit wrote:Yeah there is always a constant tweaking of workflow, actually I'm guilty of spending more time messing with reaper templates and technical setup than recording or mixing at times
Mike Stranks wrote:Of course, there are other 'standalone' software editors that will doubtless now be suggested. I found Goldwave over 20 years ago through Google... it's stood me in very very good stead over the years and I know it (the bits I use all the time) so well I can rattle along at a brisk pace.
CS70 wrote:As a friendly suggestion, don't overthink these things. Just do.
Then, Mike's control questions - does it work and is it driving you nuts while doing so - are the right thing.
There's absolutely no point in worrying about problems you don't know you have.. and most likely won't have. Because again, comping is not complicated and just buy doing it you will figure out an efficient workflow for yourself. And make music instead of tinkering.
Mike Stranks wrote:Ah no! I mean 'Standalone' as in a separate piece of software.
I use Goldwave: https://www.goldwave.com/goldwave.php
I got it long before I got a DAW... It's a one-off payment with frequent updates. Some excellent features - eg I've recently discovered that it has a LUFS analysis feature which gives you the readings after a sweep of a few seconds.
NB. My context may be useful... these days virtually all of my edit work is spoken word.
Sam Spoons wrote:About 20 years ago I stopped using computers for recording and reverted to hardware for exactly that reason, I was on Windows XP and Cubase.
After about 10 years a mate offered me a cheap G5 Mac. I still spend more time playing computers than is ideal but the ratio is much more acceptable. OTOH, if you were making records professionally you'd probably employ somebody to do the computer stuff for you but, as a hobbyist, there is a certain satisfaction in making the system work well by your own endevours.
Matt Houghton wrote:I wish I had more time on my hands to run through this. The thing is, Reaper makes possible so many different editing workflows, and it takes some time to figure out which way is best for you. It's ALL about the workflow. It's easy to learn to edit things to your satisfaction. It's less easy arriving at a way that you can do that quickly where it all becomes second nature. Kenny's tutorials are good. I think John Tidey did some good ones too. But really, you're going to need to figure out your own workflow and tailor Reaper's controls to suit it. What I would say is that you really should look into Mouse Modifiers. Put time into configuring those and Reaper is a frighteningly quick and powerful editing tool (particularly if you add a gaming mouse with lots of buttons... you'll barely need to reach for the keyboard at all!)
The Culprit wrote:Right I get you. I remember a program I came across years ago called sound forge that was similar I think. I thought maybe they types of programs were obsolete because of how far DAW's have come, but obviously there are benefits to still be had there.
I would consider going down that route if there were features I wouldn't get in Reaper...can you convince me?
Sam Spoons wrote:FWIW I use Reaper as my goto stereo editing programme, my wife is a dance teacher and often needs a recording edited to fit a time limit for a festival dance so I do a fair bit of it. Back in the day I used WaveLab and was disappointed when I discovered it wasn't available on the Mac but I quickly developed a workflow in Reaper that is every bit as quick and easy as WaveLab had been.
The Culprit wrote:...For guys like Mike who already have a set workflow in a standalone editor there is no need to change anything, but I doubt it's worthwhile creating a workflow that uses two different programs rather than just one.
But again, I'm happy to stand corrected if needs be!
Mike Stranks wrote:Exactly! Spot on!![]()
If I was starting over I'd have bought a DAW, found out I needed to do some editing and sussed how to do it in the DAW. That's it! No other software needed.
More of my context... I started with tape... for over 20 years. Editing was physically cutting tape. So when I finally went ITB I looked for a software 'tape-recorder' and found it in Goldwave. I actually did some fairly complex radio packages using Goldwave - with cross-fades and all the trimmings. Then someone explained how I could make things much simpler - and quicker - if I used a DAW for the mix.It clearly WAS quicker and easier... so I bought one.
Oh, you don't know the half of it! Mention 'spot erasing', 'timecode bleed', or 'edge track' to a seasoned tape-jockey and watch his face turn grey...The Culprit wrote:I don't envy you guys having to go through all that cutting tape business...we really are so spoiled in these times
