CME UF5 do faders work over midi only (no USB)
Postby dangeroubob » Sat Oct 15, 2011 9:47 pm
Hi there,
Just wondering if you can tell me........
On the CME UF5,
do all the faders and the transport controls work properly
when using it over midi only.... rather than USB?
Thinking of getting one, but i use windows 7 64bit
and there are no drivers for this, and the faders/controls
are what i want it for over other controller keyboards.
Cheers.
dangeroubob
Re: CME UF5 do faders work over midi only (no USB)
Postby DB111 » Sun Oct 16, 2011 8:39 am
As far as my UF6 connected by USB is concerned:-
With Reason, everything works
With Pro Tools, Nothing works (though I have heard of peope spending hours with Midi-Ox and getting some functions).
Cheers
Dave
DB111
Postby dangeroubob » Sun Oct 16, 2011 9:14 am
Thanks,
but I need to know if the faders will work over a
Midi connection, not the USB connection, which I can't use.
Cheers.
dangeroubob
Postby TLK » Sun Oct 16, 2011 10:55 am
they wont
TLK
Postby dangeroubob » Sun Oct 16, 2011 1:49 pm
if they wont work at all via a midi connection,
makes the thing pretty useless.
Might have to re-think it then
dangeroubob
Postby Rich Hanson » Mon Oct 17, 2011 6:32 am
I had a UF6, the next model up, and the faders worked fine over USB and MIDI.
The transport controls also worked over both, but they sent some proprietary codes over MIDI which you couldn't remap, but could be over USB.
Rich Hanson
Postby Martin Walker » Mon Oct 17, 2011 1:59 pm
I have a CME UF8 and all its faders work perfectly over the MIDI connection - I was checking them only yesterday 8-)
Postby dangeroubob » Mon Oct 17, 2011 9:28 pm
ok then, i'll give one a go,
Cheers.
dangeroubob
Postby semmytakaliuang » Thu Jul 12, 2018 9:07 am
Martin Walker wrote:I have a CME UF8 and all its faders work perfectly over the MIDI connection - I was checking them only yesterday 8-)
Hi Martin, I have my old UF6, I love this guy, but cant work with USB. And I totaly forgot what can the USB connection do with this CME, and MIDI connection dont...thanks.
Or what doenst function if using MIDI port connection
semmytakaliuang
Postby ef37a » Thu Jul 12, 2018 1:42 pm
Just dim memory of a problem with an early version of Cubase but could the issue be down to whether the DAW supports the correct MIDI control? I.e. "Mackie".
Postby Martin Walker » Fri Jul 13, 2018 2:17 pm
Hi semmytakaliuang!
The easiest approach in situations like this is to use a utility like the freeware MIDIOX, so you can monitor what data is coming out of the UF6 MIDI output as you move each control.
However, I don't recall any limitations of the MIDI output compared with the USB connection (which I abandoned after compatibility problems with USB chipsets).
Hope this helps!
Users browsing this forum: forumuser897287
