Build project - resonator guitar from recycled bits
Re: Build project - resonator guitar from recycled bits
Postby Wonks » Fri Sep 06, 2019 9:51 pm
Just keep going, Adrian. You'll get there.
You can tell your Bro to bugger off though if you want to. It is your build!
Postby adrian_k » Fri Sep 06, 2019 9:56 pm
Nearly 40 years of planing, sanding and chiselling have given him some pretty big muscles so I tend to do what he says...
adrian_k
getting better all the time..
Postby blinddrew » Fri Sep 06, 2019 10:02 pm
Plus you'd have to put up with years of 'I told you so'. :)
Postby adrian_k » Fri Sep 06, 2019 10:43 pm
blinddrew wrote:Plus you'd have to put up with years of 'I told you so'. :)
Too right..
adrian_k
Postby adrian_k » Fri Sep 06, 2019 10:50 pm
Having got over the hump, so to speak, I decided to rattle on and do something I'm a lot more comfortable with - fretting. Although just to make it more interesting, and in keeping with the reuse/recycle theme, I decided to sort through Col's tray of used frets to see if I could find enough of them to fret the Dobro. Here's the pile:
There was almost a complete set of frets that had been fitted to a restoration but due to some problem had been removed before they were stoned and finished. They had been cut for use with a bound fingerboard so there was a bit of the tang (thing that goes into the fret slot) missing at each end, but superglue would fix that. I completed the set with some offcut fret wire of the same size (2.4mm x 1.4mm approx), although judging by the colour slightly different material. Hey ho.
To fit the frets, I checked the depth of the fret slots then widened out the tops of the slots with a hacksaw, taking care to only go down the smallest possible amount, less than the depth of the saw teeth. Some people say you don't need to do this but it helps avoid problems getting the fret all the way down. Then push the fret in and give it few firm taps with a hammer.
Once all the frets are in the ends are glued down with superglue. Again, not everyone does this but it avoids problems later. Just run some glue under the ends of the fret and clamp it down for a few minutes using a fret clamp with a caul of the right radius.
Where the fingerboard is over the body you can use sliding clamps:
Then I chamfered off the fret ends using a file set at an angle along the edge of a block:
Stoning and crowning be done later. And that's it for another few weeks!
adrian_k
Postby Wonks » Fri Sep 06, 2019 10:54 pm
:thumbup: :clap:
Postby Folderol » Sat Sep 07, 2019 7:41 am
Good to see you're over the hump :)
Yes. I am that Linux nut.
Postby Wonks » Sat Sep 07, 2019 8:17 am
I'd have thought you are at a stage where you could clamp the neck to the body and fit a top and bottom E string to test the intonation out. If you need another 3-4mm of length, it's probably easier to add some wood to the back of the heel (as you are still working on it) and move the neck forwards, than to move the whole spider/resonator plate back by that amount.
Postby adrian_k » Sat Sep 07, 2019 10:28 am
Yeah now I have the frets in, next visit I’ll be rigging up a nut and saddle and looking at how it sets up.
adrian_k
Postby adrian_k » Fri Oct 04, 2019 1:08 pm
"They say we're young and we don't know
We won't find out until we're grown........"
The radio alarm goes off and Sonny & Cher kick off the day. That's right - Groundhog Day.
Remember I had this concept of building this thing using recycled bits wherever possible? Including the frets.
This month it was time to stone and profile those frets. This involves using 250 grit wet and dry paper on a long block to stone the frets dead level, then shaping the now flat tops of the frets so they are domed.
Starting with stoning, I marked the frets with a sharpie so I could see where I have been and set to with the long block. The idea is to stop when all parts of all frets have been touched:
It turns out putting those recycled frets in wasn't a great idea. In fact it was a Bad Idea. The problem was they were not all from the same supplier, and I was relying on being able to measure them by hand with calipers to check they were all the same height. It turns out they weren't. When I came to stone them level two of the frets were not being touched (see pic above), and I was having to take quite a lot out of the other frets to get down to them.
I referred the problem to the Master. He thought if I did get the other frets down to the same height as the two low ones I wouldn't have enough left to be able to crown them. Theoretically I could replace the two low ones with taller frets, but why mess about?
Out with all the frets:
Oh how we laughed..
adrian_k
Postby ManFromGlass » Fri Oct 04, 2019 1:15 pm
That didn’t quite sound like a laugh all the way over here . . . . . :think:
Postby adrian_k » Fri Oct 04, 2019 1:35 pm
@manfromglass No really it was all very jolly in the workshop that morning. Really.
So after a break for a bit of light-hearted swearing, I collected up as many of the little bits of rosewood that had splintered out when I pulled the frets as I could find, cleaned off the fingerboard, and using superglue, the splinters and sanding dust repaired the fingerboard surface as best I could. A final sand, check the fingerboard is level and still has the right camber (which it did), and start the refret, this time with new fret wire.
To do this I first cut the end off the fret wire using some flat backed cutters (normal cutters are no good as they leave a point on the cut end.) I then lay the wire along the fret slot and cut the wire to size, flat side of the cutters against the neck. Bang it in and on to the next. (Just realised in the pic below the order is clockwise rather than across)
I then superglued the fret ends and clamped them down as before, and chamfered off the fret ends. I was now back to where I had been at 6 that morning. I then stoned the frets level, this time no problem. I sat back and admired the day's progress:
adrian_k
Postby adrian_k » Fri Oct 04, 2019 2:59 pm
Next I profiled (or crowned) the frets. I used a crowning file which has two grooved edges, one deeper than the other. I used the deeper edge to take off the sharp edges caused by the the stoning until there is just a narrow line along the top of the fret where the file hasn't touched, then the shallow edge just to finish off.
Then I took a small file to the fret ends to round them over, cleaned off any superglue with a file then scraped the fingerboard to leave it clean. Cleaning up revealed a couple of tiny holes I'd missed before so I dropped a couple of drops of superglue in them and will now leave it till next month. I estimate this guitar is now 15% superglue. The frets will be finally cleaned up and polished later.
adrian_k
Postby ReadySaltedChris » Fri Oct 04, 2019 6:14 pm
So you'll soon be finished yeah?
ReadySaltedChris
Postby adrian_k » Fri Oct 04, 2019 10:24 pm
I thought that a few months back!
But construction wise I am pretty much there. I’m sure there will be some drama or other before I get there but I can see the finish line.
Once I’m happy the guitar can be set up the next big job is finishing. Lots of sanding, more sanding, even more sanding not to mention sanding and polishing.
adrian_k
Postby BigRedX » Sat Oct 05, 2019 10:28 am
Looks fantastic!
Fretting IMO always looks like the hardest part. I did a solid electric balalaika in the late 70s when the only easily available resource for making an electric guitar was Stephen Delft's series in International Musician, and any specialised tools had to made be yourself by modifying standard woodworking ones. My fretwork was passable at best so when I made a six-string electric guitar the following year I bought a ready made neck (also because it didn't have the facilities to make a truss-rod from scratch).
BigRedX
RockinRollin' VampireMan
Postby adrian_k » Tue Oct 08, 2019 9:19 am
I've done quite a few refrets but never fretted from scratch, so at least the fret slots are there (although often need deepening and/or widening depending on what's been done to the fingerboard). Tools wise having a crowning file helps enormously. When my brother started out he made or adapted all his own tools - no internet luthier supplies in those days.
This neck is on it's third set of frets and never been played!
adrian_k
Postby adrian_k » Sat Nov 16, 2019 4:52 pm
Me again.
I was looking forward to getting a bridge on this month and maybe see how it set up. Col said nah don't bother, it'll be fine we'll sort it. I might be wrong but I sense he wants me to get this thing finished and out of his workshop, just something about the way he sighs and looks to the sky when I turn up... :D
So instead I cracked on with finishing. First job - sand all of the scratches etc out with 100 grit cabinet paper:
Next job - spray a coat of AC lacquer. I'm going with AC as nitrocellulose takes longer to dry, and to keep it simple I'm not bothering with anything fancy like sunburst, just clear lacquer all the way. I've never used a spray gun so this was going to be tough enough.
I thought I would hang the guitar and spray like I've seen others do on the internet, but Col's spray booth is small and set up for the way he works. You can't get round the guitar to spray both sides, and even if you could Col prefers to hold the guitar while he sprays as he has more control. That's fine for him but holding a guitar at arms length for any length of time requires muscles I don't have. Col doesn't care, says get on with it..
I did manage to get a coat on but it was a struggle. Doesn't look too bad (below) but I'm going to have to improve quickly to achieve any sort of finish. Few runs, couple of bits I've missed.
adrian_k
Postby adrian_k » Sat Nov 16, 2019 6:50 pm
That first coat is really just to highlight any marks I missed when sanding and to start to get a bit of finish into the grain. Most of it gets sanded off. Here's what it looks like after sanding with 180 grit finishing paper.
There were plenty of scratches I'd missed, particularly on the maple neck where it's hard to tell scratches from grain in some places until you get some finish on, so I had to go at it pretty hard.
Spraying the second coat I decided to try it left handed (I'm often confused about which hand to use for things), slightly better but still getting some horrible runs:
adrian_k
Postby adrian_k » Sat Nov 16, 2019 7:01 pm
Still had sanding marks showing through so went at it again and cut back with 180 grit, then sprayed a third coat.
This is how it is going to be for a while now - spray, cut back, spray, cut back etc, using finer grade abrasives each coat. Hopefully. If all goes well it'll take 8 or 9 coats.
I decided to bring the guitar home to cut back the third coat with 240 grit so it's ready to spray straight away next visit. AC dries in a few hours so in theory could do two coats and cutting back in a day with a final spray at night, but in reality there is other stuff going on and it's pretty tiring stuff.
At this stage I'm also using lacquer to drop fill any small gaps e.g. between binding and body:
I'll drop fill several times. sanding back each time with 240 grit.
adrian_k
PreviousNext
