Zoom TAC-2 and new iMac 2017
Re: Zoom TAC-2 and new iMac 2017
Postby RevitalRecords » Thu Dec 06, 2018 12:47 am
Hey you all!
I am absolutely frustrated. Been trying for hours, following all kind of tips and leads.
Installed, uninstalled & reinstalled the last driver. Updated the TAC-2R firmware...
Also did the cable plug one by one thing. No way.
It still does not work.
My TBolt does not recognize anything connected.
The Zoom works, because I tested it myself in other computer.
This one is a MacBook Pro 2018 High Sierra 10.13.4
Please, help! & Thanks a lot in advance....
RevitalRecords
Postby ConcertinaChap » Thu Dec 06, 2018 7:04 am
G-Doubleyou wrote:Under the Apple menu/ About this Mac/ System Report, check under Thunderbolt.
Does your machine detect and identify the device.
What's the result of doing this? If you can't see the device then it's probably a hardware rather than a driver problem.
ConcertinaChap
Postby Xyntec » Sun Jul 21, 2019 12:21 pm
After messing around for almost an hour I just discovered the solution (and that's the reason I just registered on this forum). :D
After installing the drivers you need to head over to the security settings (System options --> Security), and click on the button that says "allow". Check the entry "Zoom Cooperation" and grant access. Now restart your mac and the Tac 2R should be recognized by the system. Hopefully this works for you guys as well :)
Xyntec
