the latest Behringer-gate
Re: the latest Behringer-gate
Postby Arpangel » Mon Sep 16, 2019 8:56 am
cyrano.mac wrote:You can't stop progress...
Many supercars used to have a Ford V8. The easiest way out to get some muscle in there. Today, Nissan (or Mitsubishi?) is testing a 1,5 liter four cilinder at Le Mans. The thing makes 400 HP, without even going into crazy high RPM.
I was just watching this vid, with Sylvia Massey:
https://www.youtube.com/watch?v=sTnHEHzFOFU
It's enlightening. From the gimmick, (the pickle) to the interesting. And the interesting is that any gear can do, if you're creative. Sylvia's even got an AKG C1000 and found a use for that. The C1000 is one of the most dreaded mics on the interwebs.
It shows that it isn't the gear you use, but what you do with it.
Of course, a Behringer won't sound exactly the same as it's 50 years old original. Why? Because that original doesn't sound the same as it did when it was new. Besides, I've never come across vintage gear that sounded the same as another one...
Vintage gear sounds great. Because of the way our memory works. We tend to remember the great ones and forget about the bad ones.
I think if we disregard ultimate authenticity and performance, it's really about feel, emotion, and inspiration regarding buying real vintage instruments. The wow factor before you've even played a note. Those thick aluminium side panels, the sea of multi coloured switches and knobs, the sheer size, it's all part of the whole experience for the player, and also, let's not forget, the audience. I could easily take Hauptwerk and a laptop into a church and play the organ, but it would die in comparison to hearing and "seeing" those wonderful pipes and console surrounding me.
I'm a car nut too, and I would be the first to admit absolutely, that any decent modern high performance car will run rings around its vintage counterpart. But vintage Ferraris and the like still sell for millions, and the reason is what I said above, and I want to feel like I'm actually driving something, not virtually being driven by the car.
Postby BJG145 » Mon Sep 16, 2019 9:16 am
The way their Odyssey is presented in Google is a bit unfortunate,
Postby Hugh Robjohns » Mon Sep 16, 2019 9:24 am
:lol: :bouncy: :oops:
Postby Arpangel » Mon Sep 16, 2019 10:13 am
Hugh Robjohns wrote::lol: :bouncy: :oops:
Hugh, thought I'd mention this, totally off-topic, but cars?
There just happens to be, totally beyond belief, a guy a few streets away from me with a Griff that looks exactly like mine, colour etc, I saw him parked in Tescos, and wandered over to have a chat, I said "how are you getting on with it?" His words were.....
It scares me to "b****y death"
Postby Hugh Robjohns » Mon Sep 16, 2019 10:17 am
Arpangel wrote:I said "how are you getting on with it?" His words were.....
Probably a good attitude to have towards it to stay alive! :thumbup:
Postby Hugh Robjohns » Mon Sep 16, 2019 11:10 am
cyrano.mac wrote:https://www.youtube.com/watch?v=sTnHEHzFOFU
:lol: I can think of lots of uses for the C1000 too... and not all of them as the designers intended... :o
Huge respect for Sylvia's work, and -- as you say -- creativity trumps almost everything else... -- but not safety!
Am I the only one that gets really frustrated when someone so apparently knowledgable spouts utter technical rubbish in a way that others are likely to believe to be true! For example, she talks about how she wired a battery into a vintage telephone handset "to raise the output to line level"... (11:10 into the video). Arrgghh... That's an embarrassing and fundamental non-understanding of the operating principle of a carbon microphone right there...
In case anyone is still reading my mini-rant... diaphragm movement in a carbon button microphone causes varying pressure between carbon granules which results in a varying resistance, but that can only be translated into a varying electrical voltage -- which is what most mic preamps require -- if the capsule is biased with a DC voltage -- hence the need for the battery. It has nothing whatsoever to do with "raising the signal to line level"... :crazy: Hope she get's it right for her new book... ;)
And hopefully, the story about the band and the faulty amp is embellished... because it's quite horrific to think Sylvia would encourage and allow anyone to use a known dangerously faulty amp (16:20)... :o :o :o :o
Postby Arpangel » Mon Sep 16, 2019 11:20 am
The only reason I haven't "floored it" yet is because I'm scared of ending up facing the opposite direction.
I need to go on a track day, where I can really get a feel for how it behaves at limits.
Better get back on topic now!
Postby Dave B » Mon Sep 16, 2019 2:44 pm
Hugh Robjohns wrote: .. she talks about how she wired a battery into a vintage telephone handset "to raise the output to line level"... (11:10 into the video). Arrgghh... That's an embarrassing and fundamental non-understanding of the operating principle of a carbon microphone right there...
I was a bit confused by that, but let it slide as it's not unknown for people to mis-speak when on camera.
Dave B
Postby arkieboy » Wed Sep 18, 2019 9:34 am
Wonks wrote:Certainly on Duke.
Yes, not their finest hour.
Each to their own on this. Certainly there's some foreshadowing of the pop orientation of Face Value which was released the following year, but we'd already seen bits of this on 'And Then There Were Three ...'.
According to wikipedia, https://en.wikipedia.org/wiki/Duke_(album) most of the album was originally intended to be a 30min extended suite starting with 'Between the Lines' and ending with 'Duke's End' and I rather fancy that the playing order remains faithful to the original sequence, with the only proviso that 'Turn It On' was thought to be strong enough to be a song in its own right rather than a section of a song. If you strip out the faff you're left with one glorious slice of music that stands firmly alongside Trick or Wind.
And forgive me for being contrary here, and as much as I love the Gabriel era, four piece Genesis remain the highlight of the band, the lack of PG allowed Hackett and Banks to really dig into the instrumental sections.
Anyway I digress. I am now utterly torn. Odyssey or Quadra?
arkieboy
Postby N i g e l » Thu Sep 19, 2019 10:59 am
BJG145 wrote:
That K-2 looks & sounds interesting. :clap: :thumbup:
Not many demos on youtube yet.
The styling is very close to the original; I dont know how they get away with it !
Postby ManFromGlass » Thu Sep 19, 2019 1:14 pm
Do you think they pay a royalty?
Postby N i g e l » Thu Sep 19, 2019 1:44 pm
ManFromGlass wrote:Do you think they pay a royalty?
I havent a clue but I would guess no, or maybe at iTunes rates.
I was just a bit shocked to see a copy as the original MS20m is only 5 years old (although as a limited edition, its out of production)
Supermarket own brand products often come close to the originals.
Postby Dave B » Thu Sep 19, 2019 2:26 pm
Now I want biscuits! damn you .... :bouncy:
Dave B
Postby BillB » Thu Sep 19, 2019 2:54 pm
We've forgotten the crackers, Gromit!
https://www.youtube.com/watch?v=KvjBv1_5yt4
(about a minute too long, but good fun...)
BillB
Postby The Elf » Thu Sep 19, 2019 6:05 pm
N i g e l wrote:The styling is very close to the original; I dont know how they get away with it !
They don't 'get away with it' - the whole point is that these things are meant to replicas/clones, as near as possible!
Users browsing this forum: arkieboy, BJG145, Kwackman
