Bricasti M7 - worth it?
Postby CS70 » Fri May 11, 2018 9:52 am
I could get a Bricasti unit at a quite reasonable price (cheap it ain't, but much less expensive than otherwise) and could be an option to re-invest some music proceedings in getting even better quality productions.
I am inclined to pass, as I think I can get pretty much the ambience I want using reverb and delays and don't feel my knowledge of reverbs is such that I have reached the limits of the kit I have. I also can use UAD plugins on my Apollo, so for a (quite) smaller amount of money I can get any of their reverbs, should I feel the need. Also, the Bricasti is an algorithmic reverb, so nothing that in principle cannot be reproduced on any computer.
Yet, I've never tried an M7 - and everywhere I look, I read it's gold.
Anyone here with first hand experience? New, it's a bloody large amount of money for a DSP (which will soon be outdated) and some code. Used, it's still a very large amount of money - the one I can get is just.. large. Is it really that different?
Re: Bricasti M7 - worth it?
Postby Sam Inglis » Fri May 11, 2018 9:59 am
If you want a flavour of the Bricasti sound you could try out the LiquidSonics Seventh Heaven plug-in, which recreates all the Bricasti presets using a form of dynamic convolution.
They do sound great to my ears.
Sam Inglis
Postby Hugh Robjohns » Fri May 11, 2018 10:00 am
I think the Bricasti is probably the best-sounding hardware reverb on the market at present. But, as always, it's a case of diminishing returns and the very small perceived quality advantage it offers over other reverb models costs a disproportionate amount.
Only you can decide whether investing that amount of money is worthwhile -- either to the sound of your mixes, or to your peace of mind in knowing you're using the best possible tools.
Personally, I'm quite happy to stick with my old hardware reverbs (Lexicon PCM90 and TC M-One) along with UAD's various classic and modern reverb plugins... But if someone offered me a Bricasti at silly money, I'd consider it very seriously!
FYI There are a lot of Bricasti IRs available on line which you can run in the convolution plugin engine of your choice. I don't think they sound exactly the same... but they are very popular!
Postby Forum Admin » Fri May 11, 2018 10:19 am
Hugh Robjohns wrote:FYI There are a lot of Bricasti IRs available on line which you can run in the convolution plugin engine of your choice.
I use the Simplicity M7 Impulse Responses with Studio One Pro's native Open Air convolution reverb, and they work well, and give a realistic flavour to the mix.
Available as donation ware from: http://www.samplicity.com/bricasti-m7-impulse-responses/
SEARCH 10,357 top articles: www.soundonsound.com/search
*NEW* SOS Video Tutorials: www.soundonsound.com/tutorials
Postby CS70 » Fri May 11, 2018 10:19 am
Thanks guys, I think I have my answer - I'll try the convolution plugin and see what I can hear :)
Postby The Elf » Fri May 11, 2018 11:45 am
Depends on what DAW you are running, but you may already have a convo-verb in there. I find that running a few choice impulse response's in Cubase's Reverence is good enough most of the time.
Postby Martin Walker » Sun May 13, 2018 1:34 pm
I reviewed these Samplicity IRs way back in one of my PC Notes columns, and have since befriended their developer Peter Emanuel Roos on Facebook, and they are still the best M7 captures I've heard :thumbup:
He REALLY knows what he's doing: www.samplicity.com/about/
Postby CS70 » Sun May 13, 2018 8:29 pm
Thanks Martin, haven't yet the time to try them out but I'll be more than happy to pay some money for them if I'm able to make use of them!
Postby CS70 » Sun May 13, 2018 8:36 pm
The Elf wrote:Depends on what DAW you are running, but you may already have a convo-verb in there. I find that running a few choice impulse response's in Cubase's Reverence is good enough most of the time.
Thx Elf, yes I have PerfectSpace - still 32bit but works just fine in Cakewalk.
Postby ManFromGlass » Sun May 13, 2018 11:19 pm
to misquote Spinal Tap "but it goes to 11"
Replace with "but it's a Bricasti"
Sometimes the inspiration from an expensive piece of gear makes it well worth the price of admission.
Signed,
Devils Advocate
:madas:
Postby Jack Ruston » Fri May 18, 2018 2:39 pm
No, it's not worth it*
It is amazing. There's no doubt about that - it sounds lovely. But it will not sell one more record, yield one extra download or stream, youtube play or sync. The quality of plug in reverbs, even basic ones, is enough that you can almost always get the job done very well if you have the skills and experience. And we're not typically up against it on the processing front at the moment either - we don't need to 'save cpu' all that much in the way we used to.
And there's a downside to any stereo hardware reverb - it's a single stereo hardware reverb. You can't have a handful of them doing different jobs, and you need to interface with the unit, recall it later, etc.
*The caveat, and there always is one, is that if money is no object, you'd have the best. And for some things, the bricasti is the best. If you were mixing films, orchestral scores etc at the top of the industry, with an effectively limitless budget (at least in this context) then you'd have four of them with a controller.
So, anyway, in short no. And I have owned and sold one for the reasons above.
J
Jack Ruston
Postby CS70 » Fri May 18, 2018 8:18 pm
Jack Ruston wrote:No, it's not worth it*
J
Well put, Jack. Indeed, it's been long time since I couldn't get exactly the kind of ambience I want with nothing more than an old convolution reverb, four/five impulse responses and a good delay. For a moment, the allure of the "magic box" had tempted me, but agree it makes very little sense unless money is no object, which is not, alas, the case for me :D
