Recording classical choir: what technique and what mic stand?
Re: Recording classical choir: what technique and what mic stand?
Postby Hugh Robjohns » Fri Jun 29, 2018 2:31 pm
NT55s I think, so cardioid capsules for ORTF. The omni capsules have a mighty peak of +8dB at 10kHz, so they would appear to be equalised for the diffuse (distant) field.
I suspect the lack of perceived brightness or clarity is either down to placement or the room acoustics.... or it could be the choir itself not having great diction I suppose.
Postby Guitarking » Sun Jul 01, 2018 9:10 am
I used cardiods.
I think my ears were blocked, sounds like good high end after all.
How do I upload an excerpt from the recording?
Guitarking
Postby blinddrew » Sun Jul 01, 2018 9:21 am
This forum doesn't host any content so most people use a private link to soundcloud or dropbox (other file sharing tools are available).
Postby blinddrew » Sun Jul 01, 2018 9:06 pm
Just had a quick listen on the laptop and it sounds ok to me, waveform looks fine on Reaper too. There's content all the way up so if you did want it a bit brighter then a gentle high shelf should be fine.
As usual though I will steer you towards the disclaimer in my signature...
Postby Guitarking » Tue Jul 03, 2018 11:30 am
Thank you blinddrew!!
Anyone else would like to have a listen?
Guitarking
Postby Hugh Robjohns » Tue Jul 03, 2018 11:43 am
Difficult to tell from such a short clip, but it sounds pretty good to me. Nice stereo width. A slightly distant perspective but it works in context. Good job.
Postby Guitarking » Tue Jul 03, 2018 7:31 pm
Hi Hugh,
Yeah, that's the strange thing. If I would have put the mic stand closer, it would have been more direct, but even now the mics were pointing a bit inwards the choir, so I was afraid the extremes of the choir would have been compressed, but I have the idea it's wide but could have been wider. That's what's puzzeling me.
Guitarking
Postby Bob Bickerton » Tue Jul 03, 2018 9:49 pm
Just a note of thanks to John and Hugh about those app suggestions, they are very useful indeed. Combined with an ‘Airmeasure’ App, you have a complete set of tools for microphone positioning.
Bob Bickerton
http://www.bickerton.co.nz
Users browsing this forum: Scouser
