Snake oil?
Re: Snake oil?
Postby ef37a » Fri Sep 21, 2018 11:30 am
I remember the 401! Was that the TT with that clever eddy current brake speed controller or was that just the 301?
I seem to recall the Garrad tables were never top choice of the audio cognoscenti because of the rumbly jokey wheel drive.
Thorens were THE machines to have, until the all conquering DD Technics came along.
I could afford NONE of them! I had a BD1 kit, a home made arm and only got as far up the cartridge food chain as the M75e!
Re: Snake oil?
Postby Sam Spoons » Fri Sep 21, 2018 12:08 pm
I sweat blood to get my system back then, reading all the Hi-Fi mags and researching different kit. I ended up with the aforementioned Sansui 222, a Sugden A48 and KefKit Chorelli's. I haven't read a Hi-Fi mag since ;)
Re: Snake oil?
Postby Hugh Robjohns » Fri Sep 21, 2018 12:18 pm
ef37a wrote:I remember the 401! Was that the TT with that clever eddy current brake speed controller or was that just the 301?
They both used the Eddy-Current brake idea.
:-) Not sure if that typo was intentional or not... a jokey jockey wheel!
Yes, the jockey wheel drive is a simple design... but actually it really does work remarkably well when set up correctly and with the turntable mounted in a proper plinth.
I have a majorly re-engineered 301 which has been substantially upgraded to incorporate the worthwhile developments introduced with the 401 (but with much better quality control!).
It has a solid CNC-machined brass chassis (rather than the 301's rather disappointing cast aluminium) to give it much more stiffness around the main bearing. The bearing is also heavily upgraded to cope properly with an oversized 10kg brass platter (7kg heavier than the original which was cast aluminium). Apparently, very few of the original platters were ever properly balanced due to casting anomalies, and although Garrard tried to balance them by drilling holes, they remained a source of rumble and vibration.
The desk is partnered with an SME M2-12R 12-inch arm fitted with a Dynavector pickup, and the whole lot is mounted on a very heavy slate plinth with isolating support legs. It sounds superb without any hint of rumble, wow or flutter... and no microphony at all... so you can hear all of the inherent imperfections of pressed vinyl discs perfectly... :lol:
I've had a couple over the years. A 166mk2 was my first hi-fi turntable in 1982, (partnered with a NAD 3020A) and I had a TD160 much later. The whole 'suspended sub-chassis' design with belt-drive is very good, but I much prefer the 301. ;-)
I believe the infamous Linn Sondek was based on the design of the Thorens TD150 and Ariston RD11, although it has evolved somewhat from those 1970s origins (and enjoyed massive price rises along the way). I still have a Linn Axis turntable in my office which is an ingenious budget design from the late 80s that I like a lot. I've also used a lot of Technics DDs professionally, but never really liked them from a hi-fi perspective.
Re: Snake oil?
Postby Hugh Robjohns » Fri Sep 21, 2018 12:19 pm
Sam Spoons wrote:I haven't read a Hi-Fi mag since ;)
Very wise! :lol: :bouncy:
Re: Snake oil?
Postby blinddrew » Fri Sep 21, 2018 12:32 pm
If I recall from a previous thread, I think there are a surprising number of Sansui 222 owners on this forum (I'm another).
Re: Snake oil?
Postby Sam Spoons » Fri Sep 21, 2018 12:46 pm
I went from listening to Hi-Fi systems back to listening to music almost overnight :)
blinddrew wrote:If I recall from a previous thread, I think there are a surprising number of Sansui 222 owners on this forum (I'm another).
For those of us of a certain age it was the magazine's budget favourite back in the day. IIRC We all lusted after a Rega Planar and admired the Linn from afar (financially at least). All were a step up from the Garrard SP25 I had before.
Re: Snake oil?
Postby Martin Walker » Fri Sep 21, 2018 12:50 pm
I started out with a Thorens TD150 too! 8-)
Garrard had ended up in a greatly reduced state by the time I joined them, and my main claim to fame while I was with them was redesigning and streamlining the motor control circuitry, which saved around 13p per board. I was a hero that week!
Sad but true - by then, saving pennies across the entire turntable range was applauded, as keeping the price competitive seemed the only way forward.
Fascinating job though while it lasted, but then I moved on to Atari and entered a whole new world of computing 8-)
Re: Snake oil?
Postby Wonks » Fri Sep 21, 2018 1:20 pm
Martin Walker wrote:Fascinating job though while it lasted, but then I moved on to Amstrad and entered a whole new world of shame 8-)
:o :o :o :o :o
Re: Snake oil?
Postby ef37a » Fri Sep 21, 2018 1:33 pm
Hugh, that is not a 301 anymore. More like "Trigger's broom"!
Re: Snake oil?
Postby Hugh Robjohns » Fri Sep 21, 2018 3:01 pm
Yes. Quite right!
It's the same design, though, and still uses many original parts in the linkages and knobs etc, but it is manufactured and built properly, the way the designer had originally intended, rather than being manufactured on the cheap in a way that emasculated the quality of the design. It is a very clever and elegant bit of engineering, though, and quite stunning in its upgraded form.
Interestingly, many of the upgrades on my model are very similar to those introduced by the Beeb's in-house engineering department when they employed 301s in the original RP2/1 studio turntables. The 401 turntable was used in a later version called the RP2/6.
http://www.orbem.co.uk/grams/grams_3.htm
Users browsing this forum: dpete
