Pops and Clicks Gradually Getting Stronger - Can you help?
Re: Pops and Clicks Gradually Getting Stronger - Can you help?
Postby Piskeh » Thu Oct 18, 2018 7:20 pm
ef37a wrote:Hope you are sorted soon. Note, one of the things that is notorious for causing audio problems is any kind of wireless kit. You might need to disable wireless adaptors in Control Panel>Device Manager but before you do any such hacking, set a Restore point.
Wow, wireless adapters can cause problems like that? I'll try disabling mine and see if that helps at all.
Thanks!
Piskeh
Postby Pete Kaine » Fri Oct 19, 2018 9:27 am
As can pretty much any other device in there, if it has an errant driver. The tests I mentioned previously would tell us if this is indeed the case, rather than you spending your time turning stuff on and off blindly.
Pete Kaine
Postby Piskeh » Mon Oct 22, 2018 1:33 pm
I'm recording in 44.1khz and that seems to have alleviated the noise I was getting. Thank you all for your help! Also, I am now using the Focusrite plugin, and I did find out how to set it up as an output device as well as an input device. So, that takes care of pretty much all of my problems now!
Happy recording!
Steve
Piskeh
Postby Wonks » Mon Oct 22, 2018 1:37 pm
Great stuff! :thumbup:
