I hoping Desmond might be able chip in with this one as he is the resident Logic expert.
I have bought a new MBP and rather than do what I usual do (clone the drives) I have done a fresh install of everything I need. However, I need to pull some of my Logic files over to the new machine.
I have an image of my old MBA drive on an external HDD so in theory it should be a fairly simple task. There are some audio files and some general program files to move over. Which bits need to be transferred and where do I find them?
Cheers.
Logic X files
• Page 1 of 1
Guido3 - Regular
And Bagpuss, once he was asleep, was just a saggy old cloth cat.
Re: Logic X files
Guido3 wrote:I hoping Desmond might be able chip in with this one as he is the resident Logic expert.
I heard the batphone go off..
Guido3 wrote:However, I need to pull some of my Logic files over to the new machine.
What files? Projects?
Guido3 wrote:I have an image of my old MBA drive on an external HDD so in theory it should be a fairly simple task. There are some audio files and some general program files to move over. Which bits need to be transferred and where do I find them?
If you've installed Logic, and the factory content, (and whatever third-party plugins you use, if any) then the only other things you need are *your* files - so, any presets/plugin settings you've made, EXS instruments, third-party impulse responses, that kind of thing, together with your projects and audio files if they are in a different place. And wherever your sample libraries are.
For Logic, the user stuff will generally be (unless you've aliased it elsewhere) in:
~/Library/Application Support/Logic/
~/Music/Audio Music Apps/
~/Library/Audio/Presets
Oh, and you'll likely need your prefs:
~/Library/Preferences/com.apple.logic10.plist
~/Library/Preferences/com.apple.logic.pro.cs
And perhaps your plugin manager database if you've organised your plugins...
(They are all within your user/home folder, that's what "~" means...)
desmond - Jedi Poster
Re: Logic X files
Most excellent.
I’ve installed all plugin content/plugins etc..... I just need my project data which should be where you say. I’ll have a fiddle tonight.
Thanks Desmond
Thanks Desmond
Guido3 - Regular
Re: Logic X files
Desmond,
All sorted and working a treat. Pint in the post.
Cheers.
Guy
Cheers.
Guy
Guido3 - Regular
Re: Logic X files
One of these days Desmond is going to call in all the pints he's owed and he'll never need to open his wallet in a pub again.
blinddrew - Jedi Poster
Re: Logic X files
Guido3 wrote:All sorted and working a treat.
Great! Thanks for posting back with the outcome.
blinddrew wrote:One of these days Desmond is going to call in all the pints he's owed and he'll never need to open his wallet in a pub again.
It's Ok, I'm not much of a drinker anyways...
Re: Logic X files
I hope he has a replacement liver on order then!!!
Guido3 - Regular
Re: Logic X files
Maybe I should get a Starbucks reward card people can contribute to...
