Music theory - sharps or flats?
Postby BJG145 » Sun Apr 14, 2019 1:58 pm
This is something I never properly understood.
I'm currently trying to write out a simple version of the chords for Paul Young's "I'm gonna tear your playhouse down" transposed from G to Eb.
So, for the verse:
https://youtu.be/YTWt_pKiMl4?t=20
I've put:
Ebm Abm Ebm Abm
You think you got it all set up, you think you got the perfect plan
Ebm Abm Ebm Abm
To charm everyone you see, and playing any game you can
Bbm Abm Bbm Abm
But I've got news for you, I hope it don't hit you too hard
Db B B Db
One of these days while you're at play, I'm gonna catch you off guard
...now, those might not be exactly the right chords, but I'm not bothered about that at the moment; it's in the ballpark.
What I'm unsure about is whether I should have written B or Cb in the last line (or even C# instead of Db), and I'm hoping someone can give me a quick explanation of the music theory there. I've gathered that how you write a note depends what key you're in, but I'm not sure if there's been a key change...?
Re: Music theory - sharps or flats?
Postby Hugh Robjohns » Sun Apr 14, 2019 2:19 pm
Db Cb Cb Db
If it's in Ebm the scale notes are: Eb, F, Gb, Ab, Bb, Cb, Db, and Eb. So it would be logical to write those chords as Cb. ...but my musical theory stopped at Grade V a very long time ago! ;-)
Postby Guest » Sun Apr 14, 2019 2:34 pm
I would say definitely Cb. From the chords you gave the piece appears to be in Eb minor and there is no B in either Eb harmonic minor or Eb melodic minor: Eb melodic minor has C♮ascending and Cb descending and in Eb harmonic minor it is always Cb. It is not a key change within the context of a pop song although some classical theorists would probably say it is modal.
If I were sight reading these chords and saw Db B B Db I would probably assume it was a copying mistake and play Bb minor.
Guest
Postby Guest » Sun Apr 14, 2019 2:43 pm
Hugh Robjohns wrote:Db Cb Cb Db
Actually they're not, that is an Aeolian mode on Eb you have shown. The Eb minor scales are:
Harmonic minor: Eb F Gb Ab Bb Cb D♮ Eb - ascending and descending
Melodic minor ascending: Eb F Gb Ab Bb C♮ D♮ Eb
Melodic minor descending: Eb Db Cb Bb Ab Gb F Eb
However I think you are correct in treating this as an Aeolian mode instead of an Eb minor scale - so you are right, but gave a wrong reason.
Guest
Postby blinddrew » Sun Apr 14, 2019 2:46 pm
This thread perfectly encasulates why every time I have tried to think about learning to understand music I just go off for a cry in the corner instead.
Postby ef37a » Sun Apr 14, 2019 2:58 pm
Whaaaa!
Wen I was in a band the Beatles were just coming into their stride and we would buy the piano copy sheet for the latest words and chords.
Invariably it would be in a key nobody could sing or, often in e flat which is a puny chord on guitar. I got the job of transposing the chords just by moving them en bloc up or down the fretboard.
It was decades later that a musically educated son made me realize (but still not properly understand!) that A sharp is not always the same chord as B flat.
Dave
Postby Guest » Sun Apr 14, 2019 3:05 pm
ef37a wrote:It was decades later that a musically educated son made me realize (but still not properly understand!) that A sharp is not always the same chord as B flat.
Dave
Much of it is just clarity and convention. A rock chord chart written C Bb F G is easy to read; C A# F G would be really confusing. The other thing is much rock music is often better considered as modal instead of diatonic.
Regarding A# and Bb, before equal temperment they were different. However some violinists still claim they play a slightly different note if it is A# or Bb: this is not borne out in practice when playing in equal temperment.
Guest
Postby ef37a » Sun Apr 14, 2019 3:08 pm
Dave
Much of it is just clarity and convention. A rock chord chart of C Bb F G is easy to read; C A# F G would be really confusing. The other thing is much rock music is often better considered as modal instead of diatonic.
Well of course, goes without....
Postby CS70 » Sun Apr 14, 2019 6:06 pm
ef37a wrote:Whaaaa!
Dave
Lots of rock is played tuning guitars and bass half step down, but probably the people writing the scores had no idea so wrote down E flat :-D
For accidents, it’s the same in theory for fretted or keyboard based instruments in equal temperament; but in practice, everyone apart from piano players often uses micro-bends, so depending on the pitches one’s used to, they can still be played slightly different when coming from below or above. Never knew anyone notating this tough in any way but it’s the same with most things you do with the guitar, there’s just no notation for it
Postby BJG145 » Sun Apr 14, 2019 7:00 pm
...OK! Thanks for the explanations...
Postby Sam Spoons » Sun Apr 14, 2019 7:47 pm
Or to put it more simply (my theory didn't get past grade 1, or up to it actually) you can't have two B's in a scale 'cos they'd be sharing the same line/space on the manuscript.
Postby Guest » Mon Apr 15, 2019 8:50 am
Sam Spoons wrote:you can't have two B's in a scale 'cos they'd be sharing the same line/space on the manuscript.
That occurs in an octatonic scale:
http://decipheringmusictheory.com/?page_id=724
Guest
Postby BJG145 » Fri Apr 19, 2019 2:04 pm
...incidentally I just dialled up a Top of the Pops version on YouTube to see what they used for the organ sounds, and I was shocked to see the keyboard player giving his Oberheim OB-XA a sharp knee jab for emphasis.
https://youtu.be/148bTZCc6E8?t=61
I don't think you'd see many players treating their analogue polysynths like that these days.
(All mimed of course. Pino Palladino tends to get more praise than Paul in the comments sections...what a bassist...)
Postby MOF » Fri Apr 19, 2019 2:42 pm
I wouldn’t use any music show for reference as to what instruments were used, many a time I’ve heard Grand Piano emanating from a Wurlitzer or Rhodes piano or indeed a Hammond organ.
MOF
Postby BJG145 » Fri Apr 19, 2019 4:40 pm
...yep, quite right. I was naive enough to be surprised to see the same OB-XA being used to reproduce the legendary "Orch 5" Fairlght orchestral hit used on this track.
(...then tried tracking that down, without success. I have Arturia's Fairlight, but their version is diabolical. Sounds like gunfire.)
