Leads
Leads
Postby Scouser » Tue Jun 18, 2019 5:42 pm
Time I replaced my old leads, getting a bit tired now, had them for years. Just standard mic, guitar and patch leads. Colour coded if poss. I thought this would be the best place to ask, don’t want to spend a fortune.
Scouser
Re: Leads
Postby Eddy Deegan » Tue Jun 18, 2019 6:34 pm
The cheapest way to do it would be to make your own. Canford do a wide range of cable types and if you search the forum for 'Canford' you'll find a few posts discussing the subject.
Re: Leads
Postby Sam Spoons » Tue Jun 18, 2019 6:36 pm
Teach a man where to buy good leads and he'll have good leads for a couple of years, teach him to solder and he'll have burned fingers for life :D
Re: Leads
Postby Hugh Robjohns » Tue Jun 18, 2019 6:43 pm
Scouser wrote:Time I replaced my old leads, getting a bit tired now, had them for years.
What does 'tired' mean?
Some of my cables are over thirty years old and are still absolutely fine.
The key is good quality connectors (I prefer Neutrik, but Switchcraft and Cannon are okay; avoid the cheap versions...) and good cable (I use Canford and VDC; sensibly prices, sensible specs, all the colour options you could want, and dependable). Avoid anything with monster in the name, or with silly constructions, or with claimed directional signal flows....
...don’t want to spend a fortune.
Best if you learn to make your own cables then. If that's of no interest there are plenty of one-man-bands around who will make custom cables to order with the right bits in the right way.
Re: Leads
Postby Music Wolf » Tue Jun 18, 2019 7:07 pm
Of course you could learn how to solder (not that difficult, plenty of 'how to' vids on line, a temperature controlled iron isn't very expensive etc) then you could buy Neutrik connectors and good quality cable and make up leads of the right length, colour coded if you prefer, that will last a life time, or............................................
Visit https://www.russandrews.com/ or https://zaolla.com/collections/guitar-cables. You won't have to worry about signal quality because you will no longer be able to afford the kit at either end.
Music Wolf
Re: Leads
Postby Eddy Deegan » Wed Jun 19, 2019 2:31 am
Sam Spoons wrote:Teach a man where to buy good leads and he'll have good leads for a couple of years, teach him to solder and he'll have burned fingers for life :D
A few less scars on the wallet though ;)
Music Wolf wrote:Visit https://www.russandrews.com/ or https://zaolla.com/collections/guitar-cables. You won't have to worry about signal quality because you will no longer be able to afford the kit at either end.
Flippin' 'eck! I need to stop clicking on links like these because it makes my blood boil, but thank you for the great examples of squamata-related lubricants :clap: :o
Re: Leads
Postby Hugh Robjohns » Wed Jun 19, 2019 9:07 am
Eddy Deegan wrote:....great examples of squamata-related lubricants
:D Must try and remember that one! :clap:
Re: Leads
Postby Brian M Rose » Wed Jun 19, 2019 12:03 pm
Yes, it's really annoying. We can just smile, but there are those out there who will buy anything. I remember being shocked at my local HiFi shop at seeing a 1M BNC cable costing more than a 100M drum of PSF 1/3 cable ; about £100.00. And yes, this was a M*****r cable. The salesman told me that the BBC ONLY used M*****r cable. I was a little surprised as I explained, that I had just installed the cameras for Grange Hill, and that we had used PSF 1/3 cables (from Canford I believe.)
I was told in no uncertain terms that I didn't know what I was talking about and that there was no such cable.
You can't win. Mind you, I did use those £500.00 super 13A fuses :lol:
Brian M Rose
Re: Leads
Postby Hugh Robjohns » Wed Jun 19, 2019 12:24 pm
Ah yes... they sound really warm and lush... I use them too... :beamup:
Re: Leads
Postby kingmoot » Wed Jun 19, 2019 12:43 pm
I've just re-wired my studio with Stagg cables and I'm pretty happy with the build quality of said cables.
https://www.staggmusic.com/en/products/ ... dio/cables
kingmoot
Re: Leads
Postby CS70 » Wed Jun 19, 2019 1:19 pm
It's not only audio.. the video/filming world is full of absolutely mundane stuff which is priced astronomically more than the same mundane stuff sourced from somewhere else... but which people buy. Differences of 1-2000 % in price aren't unusual.
For example, I was planning a night filming session the other day and realized I had lost a connection wire. Needing it in a hurry, I went to the local foto/film shop. Which I never use, and I remembered why.
The cable in question is a thin D-TAB to DC-in, about 10cm long. Goes from a V-Mount battery attached to the back of a led light panel to the DC in of said panel. It's thin wire and two plastic connectors: a little copper, a little rubber and a little plastic. I can source it for less than a dollar apiece if I have the time to wait - which is about the right price considering the marginal costs, plus a quite hefty percentage in profit. The bloody cable costed me 45 dollars!
At least tough nobody told me it was a special customized cable. That would have costed 450.. :D
Re: Leads
Postby ManFromGlass » Wed Jun 19, 2019 1:40 pm
Don’t get me started on Apple cables - grrrr.
How the hell does the software know that it’s not an Apple approved cable?
Perhaps it can sense the cable was affordable?
Re: Leads
Postby CS70 » Wed Jun 19, 2019 1:43 pm
Inside an Apple cable there’s a chip whose function is to say “I am an apple cable”
And of course you pay for it, it’s quite an expensive chip!
Re: Leads
Postby Sam Spoons » Wed Jun 19, 2019 1:47 pm
The nice thing is that PoundLand cables have a clone of the same chip so work just fine for a while at least. TBF they are not as robust but my cables don't usually last long enough to wear out as the guy lost or suffer from physical trauma......
Re: Leads
Postby ef37a » Wed Jun 19, 2019 6:51 pm
Sam Spoons wrote:The nice thing is that PoundLand cables have a clone of the same chip so work just fine for a while at least. TBF they are not as robust but my cables don't usually last long enough to wear out as the guy lost or suffer from physical trauma......
Yup. When I bought a wallet and a USB A to C cable for my new Sony android phone a month or so ago the cable was a tenner. PoundLand a quid and I can tell no difference in performance.
There are limits though? RockBottom type shops sell CAT5/6 patch cables very cheaply and I had one that had a dent in it, a moulding fault not damage, and one pair was O/C. I am also betting even a good cable would not perform to top data transfer spec? Not that it would be noticed by 99% of the public.
There are two other advantages to "rolling your own".
1) You will be able to fix cables of a Sunday night which is when one-off recording opportunities always turn up and cables fail!
2) You will be able to make "specials" which don't exist as ready mades.
Re: Leads
Postby Sam Spoons » Wed Jun 19, 2019 7:15 pm
And Poundland don't sell XLR cables ;)
Re: Leads
Postby Martin Walker » Thu Jun 20, 2019 4:05 pm
I'm afraid I had to Google it :headbang:
Bravo Eddy - I shall attempt to memorise that one for future reference as well 8-)
Re: Leads
Postby Martin Walker » Thu Jun 20, 2019 4:07 pm
ef37a wrote:You will be able to make "specials" which don't exist as ready mades.
That's how I have so many pseudo-balanced mono jack to stereo jack cables for my various keyboards Dave 8-)
Re: Leads
Postby N i g e l » Wed Jul 03, 2019 3:34 pm
Possible innovations since you bought your last lead set are the
[1] Neutrik SilentPLUG ¼” jack, which stops amp buzz when you plug a cable+amp into your guitar.
[2] Chinese manufacturing
Im not suggesting you buy from Ali-express but big suppliers like Thomann have good quality cheaper own brand cables [sometimes cheaper than the bits alone].
I agree it is worth while making your own cables for small batches and can be therapeutic too, once you learn to remember to put all the tubular bits on the cable before soldering the final connector in place. XLRs make a good starting point ‘cos the're big and the easiest to do.
Re: Leads
Postby Mike Stranks » Wed Jul 03, 2019 4:28 pm
Sam Spoons wrote:And Poundland don't sell XLR cables ;)
.... reminds me of a 'bitter experience' saw that I sometimes quote: "Never buy batteries for radio mics from Poundland."
(They die after about 40 mins... :oops: )
Users browsing this forum: Folderol, Moroccomoose, Smellthevalve
