Reorder Sends in Logic Pro X's Mixer
Postby Ylan Sthlm » Mon Aug 05, 2019 10:05 am
Dear Friends,
I wonder whether it is possible to change the order of the sends in a channel strip.
This didn't use to bother me till I started using sends to output for headphone mixes.
When I set up for tracking I normally add two sends to headphones. Then when I have added a send to an AUX for a reverb for instance, I have to go looking for the right sends if I want to change the level going to headphones since they end up in different order.
Is it possible?
Humbly, Ylan
Ylan Sthlm
Re: Reorder Sends in Logic Pro X's Mixer
Postby desmond » Mon Aug 05, 2019 11:22 am
No, but it makes no difference to signal flow, so it's purely a layout/workflow issue. If you need to change them, you'll need to do it manually.
desmond
Postby Ylan Sthlm » Thu Aug 08, 2019 1:19 pm
desmond wrote:No, but it makes no difference to signal flow, so it's purely a layout/workflow issue. If you need to change them, you'll need to do it manually.
It's (ironically?) the improvement in setting up headphone mixes that made this start to annoy me. I end up turning up reverb instead of listening level.
Cheers!
Ylan
Ylan Sthlm
Postby desmond » Thu Aug 08, 2019 1:28 pm
Remember you can rename busses with long and short names, so if you name your headphone busses, you can more easily see them in the channelstrips...
desmond
