Orchestral reverb spacing
Re: Orchestral reverb spacing
Postby Sam Spoons » Thu Nov 07, 2019 1:26 pm
Me too :D (though acoustic jazz/folk bands rather than orchestras) but I think the OP is trying to construct a realistic sounding orchestra recording from samples/VSTi's.
Postby blinddrew » Thu Nov 07, 2019 2:57 pm
Sam Spoons wrote:Percussion at back, long delay, strings at front short or no delay.
Assuming we're talking the delay on the reverb, nope.
Percussion at the back means that the sound has a short distance to travel before hitting the back wall and therefore the reflected sound arrives quicker than the reflected sound from the strings, which has a greater distance to travel (hence a longer pre-delay).
Postby Sam Spoons » Thu Nov 07, 2019 4:08 pm
That makes sense
Postby Wonks » Thu Nov 07, 2019 4:24 pm
Sam Spoons wrote:That makes sense
Drew starts to doubt himself.... ;)
Postby Moroccomoose » Thu Nov 07, 2019 4:28 pm
jimjazzdad wrote: an MS pair or maybe spaced omnis - and add a bit of Bricasti dust on the stereo bus as required. A well placed coincident pair will always give a more realistic image with depth than any amount of hocus pocus in post... (just my humble opinion; carry on!)
Of course if you have a spare orchestra and room to play them in, the well placed coincident pair will do just perfectly... But this is really about trying to make virtual (sampled) instruments sound like they are in a real space and arranged realistically.
Stu.
Moroccomoose
Postby blinddrew » Thu Nov 07, 2019 4:58 pm
Never stopped! :)
Postby Rich Hanson » Thu Nov 07, 2019 5:00 pm
Of course, for the full effect you also need to account for the wall behind the audience too and the delay situation would be more or less opposite but possibly at a lower level (yes, I know that's probably over-complicating it)
Rich Hanson
Postby jimjazzdad » Thu Nov 07, 2019 5:30 pm
Moroccomoose wrote:Of course if you have a spare orchestra and room to play them in, the well placed coincident pair will do just perfectly... But this is really about trying to make virtual (sampled) instruments sound like they are in a real space and arranged realistically.
Stu.
Sorry. I must have been asleep in mastering class when they handed out the assignment. :blush:
jimjazzdad
Halifax, NS, CANADA
Postby ManFromGlass » Thu Nov 07, 2019 7:52 pm
Ok I finally had time to give it a try in Logic. First attempt set up correctly but didn’t really work for my ears until I put the sends all to pre-fader. Then I could lower the initial sound but keep the reverb high. Perhaps this is cheat way to lose the initial bright attack of instruments at the back, rather than eq them. I was only working with 1 short repeated piano note. I know strings, horns and other slower attack sounds may not need a pre-fader approach.
I’ll keep working with it.
The other issue is the one mentioned previously about how the further the reverb source is the more mono it is, or is it the instrument that becomes more mono? I better re-read!
Users browsing this forum: Alba
