Is TV/ video/ film sound getting worse?
Re: Is TV/ video/ film sound getting worse?
Postby Rich Hanson » Fri Dec 06, 2019 7:14 am
I recall that a lot of early CDs used pre-emphasis and correctly set the pre-emphasis flag in the subcode, but many early players didn't implement the required de-emphasis, leading to overly bright playback of those discs.
Rich Hanson
Postby John Willett » Fri Dec 06, 2019 3:39 pm
MOF wrote:A lot of people seem to like vinyl, but I think that's because of it's limitations/distortions, but that's what we're talking about, it's got a sound of its own. CDs have much greater fidelity.
I think it's also because the record companies have buggered up the CD by compressing the music into oblivion because of the "loudness wars". :madas: :madas: :madas:
You can only compress lightly with vinyl which means that you still get music.
If you compressed the CD with a light touch the same way as vinyl, then the CD would be far far better. :thumbup:
John Willett
Postby The Red Bladder » Fri Dec 06, 2019 3:51 pm
John Willett wrote:If you compressed the CD with a light touch the same way as vinyl, then the CD would be far far better. :thumbup:
I have one customer that comes to me for a series of classical piano pieces about once a year and every time the label wants the thing LOUDER "We need at least another 10dB!" they insist!
I've tried arguing the point, but to no avail! The funny part is that they insist on 96kHz sample rate because they read somewhere that it is better!
The Red Bladder
Postby Sam Spoons » Fri Dec 06, 2019 3:53 pm
Do they get their extra 10dB though? :headbang:
Postby MOF » Fri Dec 06, 2019 8:36 pm
I don't know enough about vinyl mastering to comment, but if so then you have a point, I don't like the loudness wars either.
MOF
Postby MOF » Fri Dec 06, 2019 8:38 pm
It is, at the recording/mixing stage, along with 24bit (though I think oversampling at 44.1/48khz helps there, but a gentler roll off slope at 96khz is preferable) but from what I've read I don't think there's any advantage at the distribution stage.
MOF
Postby Hugh Robjohns » Fri Dec 06, 2019 11:17 pm
MOF wrote:... a gentler roll off slope at 96khz is preferable...
Just for clarity, the anti-alias and/or reconstruction filters in systems operating at 96kHz are exactly as steep as those in a 44.1 or 48kHz system. However, they start an octave higher up!
Postby MOF » Sat Dec 07, 2019 2:08 am
Thanks Hugh, that’s what I meant.
MOF
Postby John Willett » Sat Dec 07, 2019 5:41 pm
Madness for a classical piece - a reason NOT to purchase the CD.
John Willett
Postby Hugh Robjohns » Sat Dec 07, 2019 5:46 pm
The context is needed before this kind of statement can be judged.
There are and will always be cases where a degree of dynamic reduction is required to make the music acceptable for 'ordinary' domestic listening. This is probably especially true of live recordings, but applies to studio works too.
It is quite normal, and necessary to raise the quietest sections to be more easily audible to a casual listener, without the loudest bits then blowing the speakers off the shelf!
Raising the ppp sections by 10dB or so is not an unreasonable expectation or requirement in most cases, but it does obviously need to be done sympathetically...
Postby ef37a » Sat Dec 07, 2019 6:31 pm
Hugh Robjohns wrote:The context is needed before this kind of statement can be judged.
Quite! The argument for distributing 24 bit recordings comes up from time to time. Such requests ignore the fact that the 90dB range of CD is already far too great for almost any domestic enviroment. A 'house' level of even 30dB SPL is enjoyed by very few I would say? (my place, dead of, reads 25-28dBC but I think that is about the noise limit of my cheapo meter) Stick 90dB on top and you need one hell of a hi fi system!
Dave
Postby Hugh Robjohns » Sat Dec 07, 2019 6:44 pm
I think Sony/Philips decision to provide a 16-bit format with a 90-ish dB signal-noise range in the CD format is absolutely spot on... It's very sad that it's almost never been used sensibly. ... although there is still time... :lol:
Working with a nominal (average) level of -20dBFS -- as Sony originally intended -- still leaves the noise floor 70dB or so further down -- and probably 20-30dB below the quietest bits of music -- and thus the noise floor remains inaudible in all normal home setups, yet the system is still capable of a healthy 20dB headroom for the peak transients when required.
A slightly higher sampling rate would have been better and 60kHz would have been perfect for everyone's needs... but, sadly, the technology wasn't quite ready for that when they wanted to launch the format.
Postby Arpangel » Sat Dec 07, 2019 11:12 pm
Hugh Robjohns wrote:It is quite normal, and necessary to raise the quietest sections to be more easily audible to a casual listener, without the loudest bits then blowing the speakers off the shelf H
You've played the Garage Door then..... :D
Postby Folderol » Sat Dec 07, 2019 11:39 pm
Haven't we all? :shh:
Yes. I am that Linux nut.
Postby Martin Walker » Sun Dec 08, 2019 4:08 pm
ef37a wrote:Quite! The argument for distributing 24 bit recordings comes up from time to time. Such requests ignore the fact that the 90dB range of CD is already far too great for almost any domestic enviroment. A 'house' level of even 30dB SPL is enjoyed by very few I would say? (my place, dead of, reads 25-28dBC but I think that is about the noise limit of my cheapo meter) Stick 90dB on top and you need one hell of a hi fi system!
I quite agree Dave - I bought a load of CD albums from one French company some years ago, and they had an excellent reputation for sonic performance.
However, I rather went off them when they started releasing more expensive 24-bit digital downloads alongside the standard 16-bit versions. I simply find it difficult to believe that the vast majority of listeners would be able to hear any difference on already mastered output :headbang:
PreviousNext
