TYXIT T.ONE - Wireless all-in-one monitoring and mixing
Postby TYXIT » Tue Jun 23, 2020 2:39 pm
TYXIT develops next-gen plug-and-play wireless technology and brings fully wireless live music solution to bands & DJs via Kickstarter
  • Compact wireless audio system combines audio performance with ease of use
  • Features wireless monitoring, embedded mixer and recorder through virtual sound card
  • Single plug-and-play system can be fired up in seconds, controlled by an app
https://www.youtube.com/watch?v=QNv2PPNMY-w
TYXIT is a Swiss start-up specialized in wireless technology for audio. After 3 years of development, we are launching our new, next-generation technology on crowd-funding site Kickstarter. Catering to the live music industry, our wireless personal monitoring and recording audio system frees musicians and bands from cables and cumbersome set-ups. The stand-alone, portable system named the “T.ONE” – is a pocket-sized device delivering wireless monitoring, mixing, recording and more, all with ultra-low latency under 2 ms and impeccable audio quality.
Our technology is easy to use. Each musician or singer plugs a T.ONE transmitter into their instrument or microphone, the sound signals are immediately transmitted to each of the receivers plugged into the musicians’ in-ear headset and a venue’s PA sound system. A mobile app for smartphones and tablets is used to control the setup and each individual mix. In seconds – literally – a band can be operational after plugging their T.ONE devices in. Available with the usual connectors used in music equipment - 1/4", 1/8", or XLR - T.ONE transmitters are capable of transmitting high-quality audio with up to 10 simultaneous streams, all with negligible latency. TYXIT enables recording and mixing on the go and uses a proprietary radio protocol on 5.8 GHz ISM Band and audio codec for fast compression and high-quality audio.
Built using cast metal and other high-grade materials and designed with comfort and sturdiness in mind for touring and road trips, each plug device is engineered following the standards of Swiss engineering: attention to detail, impeccable finish and tight tolerances.
We aim to create a community of pioneers and for that reason launched a 30-day Kickstarter campaign, engaging directly with musicians from all walks of life through the crowd-funding campaign.
Earlier this year, TYXIT showcased the T.ONE at the CES Convention in Las Vegas, where it won a prestigious Innovation Award, and the NAMM Music Show in Anaheim. It is supported by the Swiss Confederation, the regional Vaud Office for Economic Affairs and Innovation, Venture Kick, and Accelerace.
You can back the TYXIT T.ONE on their Kickstarter page now, starting at about $249 for a pair of devices for the Super Early Bird adopters. Further info can also be found on TYXIT’s website.
Kickstarter: https://www.kickstarter.com/projects...musicians-free
Official TYXIT website : https://www.tyxit.com
TYXIT T.ONE TECHNICAL SPECIFICATIONS
WIRELESS STREAMING
• Proprietary RF protocol: 5.8 GHz ISM band
• XTrue Diversity (2x2 MIMO) technology, Forward Error Correction
• Up to 10 simultaneous transmitters
• Under 2 milliseconds of wireless audio latency
• Wireless range: Up to 30 meters (100 ft.)
RECHARGEABLE BATTERY
• Battery life: up to 8 hours
• Battery charging: 2 hours via USB-C cable
RELIABLE IN ANY ENVIRONMENT
• Dust resistant
• Water resistant (IP 54)
EXTENSIVE CONNECTIVITY
• 1/4” Jack
• 1/8” Jack
• XLR
• 48V phantom power
• USB-C to MacOS & Windows
SOUND QUALITY
• Proprietary audio codec
• Sampling: 48 kHz/24 bits
• Audio bandwidth: 20 Hz - 20 kHz
• Stereo/mono
APP
• Free Android/iOS app
Get in touch with the TYXIT team:
info@tyxit.com
TYXIT
