Am I on the Right Track?
Advice on everything from getting your music heard to setting up a label and royalties.
Postby Oneal » Sun Aug 02, 2020 6:09 pm
Okay guys,
So I have been creating music all year...and now I am ready to start releasing it.
But I want to make sure all my business is clean before I do so...
I am starting my own label as a music producer and basically just signing myself for now. I am working on a compilation album showcasing my production and songwriting with various artists performing on it. (Sort of like a DJ Khaled model)
So far I have registered my LLC with California and next I plan to register with ASCAP as a writer and publisher, register with Songtrust, Tunecore, and SoundExchange.
So should I register as an individual or under my LLC?
Also, where should I register split sheet and collaboration agreements? Because I will have a ton of those.
Oneal
O'Neal
Entegrity Records
Re: Am I on the Right Track?
Postby RichardT » Sun Aug 02, 2020 6:36 pm
If you are just releasing your own stuff I’m not sure you need to set up your own label. I’m in the same position as you and I haven’t had to do that (in the UK). It’s possible to release via a distributor without a label. Maybe things are different in the US from a tax perspective. You’ve already done it though so maybe it’s not a problem to go forward with it.
To join a PRO will cost you a fee - I wouldn’t join any until you’re likely to recoup the investment.
Have you done a comparison of distributors before settling on Tunecore? There are many different models and pricing structures.
I would also consider loading up to Soundcloud and Bandcamp.
RichardT
Samplehound-website My last album sold over a million copies - if you don't believe me, come and look in my garage.
Postby Oneal » Mon Aug 03, 2020 9:09 pm
RichardT wrote:If you are just releasing your own stuff I’m not sure you need to set up your own label. I’m in the same position as you and I haven’t had to do that (in the UK). It’s possible to release via a distributor without a label. Maybe things are different in the US from a tax perspective. You’ve already done it though so maybe it’s not a problem to go forward with it.
:problem:
Oneal
O'Neal
Entegrity Records
