Focusrite Saffire Pro 14 - Low output?
Postby HenryB » Wed May 25, 2011 12:39 pm
Hi there,
Just replaced my MOTU Traveler with a Saffire Pro 14 for downsizing purposes - but I've found the outputs on the Saffire to be really low compared to the Traveler, probably just over half the previous level.
Does anyone have any ideas/fixes that might help me get my output back up?
Thanks!
Henry
HenryB
Re: Focusrite Saffire Pro 14 - Low output?
Postby DAGGILARR » Wed May 25, 2011 6:27 pm
I had one of these and I discovered that all of the gain is bunched up at the top of the scale. I still have a Saffire 24 and its the same, all the gain is above 8 its almost as if the 0 to 7.9 may as well not be there. I also find that the adjustments between 8 and 10 need to be minute.The pre's are OK but these controls, I find, are a pain. Focusrite call this "non linear gain" or something
DAGGILARR
iMac 27" i7 2.9gh 2010 12GB ram, Focusrite Pro24DSP.
Postby Hugh Robjohns » Wed May 25, 2011 6:42 pm
It's a very common problem with 'budget' preamps, and while there are ways around it they all add to the expense.
Hugh
Postby Neokoenig » Wed May 25, 2011 7:51 pm
I find a similiar thing on the Pro40, but it's actually quite useful when you're tracking drums with no pads on the channels: you get more control over the high level volume sources..
Neokoenig
