Mid/Side advice? -U87, Rode M3, Zoom H4N, Shure SM7B
Postby MCP_Music » Thu Jan 05, 2012 1:01 pm
Hi, I have a vintage Neumann U87 and GAP Pre73, also a Zoom H4N (massive contrast I know).
If I wanted to, can I use these as a Mid/Side setup with the Neumann recording teh mids and the H4N as the sides?
OR should I use the U87 in a figure of 8 polar pattern for the sides and use another mic ie my Shure SM7B or Rode M3 for the mids?
How then would I combine the 2 into a mid/side audio file?
Randomly,
_Luca
MCP_Music
Re: Mid/Side advice? -U87, Rode M3, Zoom H4N, Shure SM7B
Postby Hugh Robjohns » Thu Jan 05, 2012 1:09 pm
Using such radically different mics to form an MS array is never going to give great results -- the stereo imaging will tend to be rather variable and frequency-dependent.
But for experimental purposes I'd suggest using the U87 in fig-8 mode for the Side mic and either the SM7 or M3 as the centre Mid mic.
All you need to create a mid-side file is allocate the mic mic to channel 1 and the side mic to channel 2, and record as a stereo file.
However, you should also ensure that the in-phase side (front) of the U87 faces to the left of the sound stage (as viewed from behing the mic array looking at the sound sources). You should also set the preamp channel gains to provide a similar sensitivity for both mics.
The easiest way to do that is to decide where you want the nominal left hand edge of the stereo pickup area to be, then get an assistant to stand there making a fairly constant noise (humming, for example). Adjust the gain of the two preamp channels to give roughly equal output from both mics.
hugh
Users browsing this forum: Tim Gillett
