FYI 'quivering boom pole'
Postby Guest » Fri Jul 06, 2012 10:59 am
More an item of (maybe) interest than a question.
I set up QP6200 ambient jumbo pole on a heavy doughty stand...with many ballast bags of sand around base as well as counterweight on boom.
Sprung gym floor.
every time people walked the vibrations set up a resonance along the boom and it started gently wavering up and down at the tip....mics moving a good few centimetres in the vertical.
I cannot detect problems in audio recording (but these were lower school orchestras and they anyway wavered a bit!)
an interesting challenge as the issue is not horizontal or back and forth and stabilising with guy lines seems precluded.
There were no air movements beyond any thermals created by audience ??
I willed it to keep still but it did not.
we will try to experiment with different extensions and curvatures of the boom to see if issue can be minimised or exagerated and therefore understood
just a thought that someone may be interested!
cheers
steve
Guest
Re: FYI 'quivering boom pole'
Postby Jorge » Sat Jul 07, 2012 4:10 pm
You may want to take some university courses in how to will more effectively without willing harder or longer.
Seriously, parameters that affect the resonant frequency of the floor/stand/boom/mic system include pole length, weight and stiffness; weights of mic and cable; and height and stiffness of stand. Playing with one or more of those may shift the resonant frequency enough that someone walking by at a normal pace won't set up a resonance in the system. Or put a thin tight guy line from the mic to the stand some distance from the boom so the tension will stabilize the boom and mic.
The sprung gym floor is a factor otherwise not present in most performance venues.
Jorge
Postby Wiseau » Sun Jul 08, 2012 3:47 pm
This thread title - Biggest...innuendo...ever.
Wiseau
Postby Hugh Robjohns » Sun Jul 08, 2012 6:04 pm
Tiny movements at base will inevitably produce larger movements at end of boom, and because there is negligible damping in the boom arm there's not much you can do about it. Placing the stand as close to the wall as possible to minimise floor movement is about all you can do. And fit windshields if air movement causes noise.
Hugh
Users browsing this forum: Random Guitarist and 7 guests
