Recommendation for good in ear phones
Postby Andy W » Tue May 29, 2012 8:47 am
Morning all,
Can anyone recommend good in ear headphones that can be used for monitoring? I normally use closed back Sennheisers but it's a bit painful on the ears when I wear glasses as well. The budget would be around £100 - £150.
Any advice appreciated. Many thanks.
Andy W
Re: Recommendation for good in ear phones
Postby SecretSam » Wed May 30, 2012 7:25 am
If by closed-back Sennheisers you mean HD-25s, I know what you mean. They squeeze my ears like an angry Jesuit working on a suspected heretic. However, this is probably what gives them their excellent bottom end and isolation.
I am also a four-eyed git, and have always found Beyer Dynamics comfy (DT-770s are wearable for hours and are closed back ... although their isolation is not as good as the HD-25s). The open-back Sennheisers (inlcuding the legendary HD-650s) are nice as well. All these headphones fit around the ear rather than on top of it, which might explain a bit.
I never did find in-ear phones comfortable for long periods, and their sound varies according to how far they get stuffed in your ears, which is not ideal.
SecretSam
Postby Andy W » Wed May 30, 2012 8:04 am
Thanks for the info. I'll have a look at the DT-770s and the HD-650s. I agree that in ear don't work for long periods, plus I worry a bit about hearing damage.
Thanks again.
Andy W
Postby Mike Stranks » Wed May 30, 2012 8:06 am
Greetings!
Are we talking monitoring whilst recording in noisy situations (and/or studio tracking) or "studio" mixing of previously recorded stuff - or all of these? :)
Whatever it is I personally wouldn't use in-ears - just too many variables and difficult to get an accurate assessment of what's actually going on.
Bearing in mind your budget, if you want a decent set of cans for mixing and critical listening I'd suggest a listen to the AKG K240 MkII. They're open-backed so no good for monitoring if recording in noisy environments - but very good for the money and very comfortable.
If you need maximum attenuation of external sounds then I like the Sennheiser HD380 Pros. Excellent isolation - better than most of the purpose-designed 'isolation' headphones - and reasonably comfortable. I can wear mine for 2+ hours no problem - and I also wear specs. However, I wouldn't choose these for critical mixing listening - the AKGs are much better for that IMHO.
HTH. Mike
The older I get, the better I used to be
