input gain plug-ins: do i need them?
Postby hopscotch44 » Fri Apr 21, 2017 10:15 am
Hello,
I have a very basic question, asked after watching a youtube video about gain staging in DAW. I'm trying to get deeper into the funcionality of REAPER. Any guidance is appreciated.
The video recommended an external plugin that was essentially a fader and gain control, to be inserted on each track as a first plug in. The process was to assess highest raw input level and reset max gain on each channel to see all max levels at unity...this is before any other work is done. This was to leave headroom especially in the Master fader level from the outset.
My question is....(and i have looked)....is this possible with some default DAW control? and is it generally a good idea?
I'm assuming recorded levels to be optimum in context.
I hope this is not too simple a question?
hopscotch44
Re: input gain plug-ins: do i need them?
Postby Kwackman » Fri Apr 21, 2017 10:37 am
Cubase has this built in to it's mixer.
I do use it, mostly on tracks I've recorded rather than software instruments, where I just use their own output control.
Following advice learnt here, I record acoustic guitar with LOTS of headroom, and on playback use the channel input gain control to lift it up 9 or 12dB, still making sure I've got at least 12dB of headroom on the mix channel with the channel fader at unity.
It means that any other plug-ins used on that channel are getting input levels at a sane level.
That workflow works for me, YMMV.
Kwackman
Postby James Perrett » Fri Apr 21, 2017 11:21 am
It depends on the other plug-ins that you are using. If a plug-in is only designed to work with a limited range of signals then a gain control before that plug-in could be useful. However, most well designed plug-ins will work over a wide range of signal levels.
In Reaper you can also change the level of a clip by pressing F2 and moving the level slider so no extra plug-in is required.
JRP Music - Audio Mastering and Restoration.
http://www.jrpmusic.co.uk
Postby CS70 » Fri Apr 21, 2017 1:29 pm
If you record everything together (or you manage to keep a similar healthy average/peak levels when recording each track) you probably don't.
But it's often the case, especially with tracks recorded at different times with different kit, that the levels aren't comparable. The you need a way to bring the levels in the same ballpark - it's just much easier to mix that way - and a way to raise or attenuate the track's base level is useful. A gain plugin is one of such ways.
Silver Spoon - Check out our latest video!
And if you like it, tells us at the FB page
Postby hopscotch44 » Wed Apr 26, 2017 4:45 pm
thanks for those replies.
first off i loaded JSutily plugin from the Reaper stock plugins and will see how that feels....it's a bit utilitarian but will do for experimenting.
any nice free GUI's around?
cheers everyone
hopscotch44
Postby djangodeadman » Wed Apr 26, 2017 5:13 pm
hopscotch44 wrote:thanks for those replies.
cheers everyone
Blue Cat Audio do a nice (and free) gain plug-in.
djangodeadman
Postby mashedmitten » Wed Apr 26, 2017 5:45 pm
I'm curious about this now. Doesn't proper gain staging eliminate the need for a gain plug? Or are we talking 3rd party tracks where you didn't have control of staging from the start? Or am I missing else?
Sorry for the OT, if it needs to be moved to its own thread, please do.
mashedmitten
Nate
Postby CS70 » Wed Apr 26, 2017 6:10 pm
mashedmitten wrote:I'm curious about this now. Doesn't proper gain staging eliminate the need for a gain plug? Or are we talking 3rd party tracks where you didn't have control of staging from the start? Or am I missing else?
Well, using a gain plugin is one of the tools for proper gain staging :)
Gain staging means simply to make sure that every gain point in your chain keeps a level within the optimal parameters for the downstream - including the software ones.
Postby Mixedup » Wed Apr 26, 2017 7:37 pm
Although there's no dedicated control by default, Reaper does, like Cubase, have a pre-insert gain parameter, and that can be shown as an automation lane, or overlaid on the media lane. So I'd use clip envelope to edit and sort levels of individual clips. Then this to set the rough level with my post-inserts fader at unity. Then apply any dynamics processing to get me as near to a decent static mix balance as possible. Then, finally, automate the channel fader to fine-tune everything once your processing and FX are applied.
Mixedup
Postby James Perrett » Thu Apr 27, 2017 9:11 am
I'd still suggest changing the level in the clip properties rather than using a plug-in. It has the bonus of displaying the waveform at the new level as well.
Users browsing this forum: No registered users and 4 guests
