Amplesound.net Releases Ample Bass Acoustic (ABA)
Postby Jason Morin » Thu Dec 10, 2015 8:10 pm
Hello!
Ample Bass Acoustic is a sample-based virtual instrument that brings
you a detailed emulation of a Guild B-54 CE. It is now available at http://www.amplesound.net for 95$ (limited time)
Sysem Requirements:
-4.6 GB of free hard disk space.
-Windows XP or newer, Pentium 4 or Athlon processor with 2 GB RAM.
-Mac OS X 10.7 or higher, Intel-based Mac with 2 GB RAM.
-AU, VST, AAX or RTAS host application and professional sound card recommended. Stand-alone version included.
Samples:
-ABA has a 4.89 GB sample library which is naturally recorded on every single fret. No destructive editing and dynamic processing are applied.
-Features 8 articulations: Sustain, Palm Mute, Natural Harmonic, Hammer On & Pull Off, Legato Slide, Slide in & out, Pop & Slap and Dead Note.
-The Legato articulations can be used to achieve legato notes of any duration, pitch and polyphony.
-Alternate Tuning. Ample Bass supports alternate tunings to the lowest note B0.
Please take the time to watch it ''LIVE'' in action:
Example 1: Acoustic Funky
Example 2: Jazz G
Example 3: Isn't She Lovely
Features:
-New sample engine applied to both plugged and unplugged
ABA is designed from the ground up to be the most versatile bass virtual instrument available today with a new level of expressiveness. ABA not only performs as an extraordinary acoustic instrument by playback partially from mic samples, but also as an electric instrument
by playback partially from DI samples, creating a more dynamic and subtle playing experience. Furthermore, users can mix and process Mic and DI separately to get a variety of sound.
-Multiple stereo and mono modes
For Mic part, ABA provides two stereo and two mono modes. Users can adjust volumes of mics and width to get more options in stereo mode, in which ABA has rich expressiveness even for solo. For mono modes, ABA can play an important role of middle-low end in a band steadily.
-New designed EQ
New designed EQ can process Mic and DI channels separately. By highlighting strong parts while avoiding weak parts, it can further refine sound.
-Tab Player
Redesigned Tab Player for bass tab. All articulations and notations are supported by the tab player. Realistic Tab playback can be achieved through fine parameter adjustments and humanizations.
Thank you!
Jason Morin
Re: Amplesound.net Releases Ample Bass Acoustic (ABA)
Postby Jason Morin » Fri Dec 11, 2015 4:35 am
Small mistake in the above post....
-5 GB of free hard disk space is needed for ABA
and
-ABA has a 4.6 GB sample library ( instead of 4.89 )
Jason Morin
Postby Jason Morin » Wed Dec 30, 2015 7:46 pm
Hello Guys wanted to say that
Amplesound.net Winter sale is ending soon ( Jan 1st 2016 ) up to 55% off
http://www.amplesound.net/en/purchase.asp
Also ! here is a Review of Ample Bass Acoustic done by Ruben from HifiMidi :
https://www.youtube.com/watch?v=u5mzAeFL-1g
https://www.youtube.com/watch?v=WqjqoAKDRRs
Thank you
Jason Morin
