Is TV/ video/ film sound getting worse?
Re: Is TV/ video/ film sound getting worse?
Postby ef37a » Sun Dec 08, 2019 5:26 pm
Hugh Robjohns wrote:I think Sony/Philips decision to provide a 16-bit format with a 90-ish dB signal-noise range in the CD format is absolutely spot on... It's very sad that it's almost never been used sensibly. ... although there is still time... :lol:
Working with a nominal (average) level of -20dBFS -- as Sony originally intended -- still leaves the noise floor 70dB or so further down -- and probably 20-30dB below the quietest bits of music -- and thus the noise floor remains inaudible in all normal home setups, yet the system is still capable of a healthy 20dB headroom for the peak transients when required.
A slightly higher sampling rate would have been better and 60kHz would have been perfect for everyone's needs... but, sadly, the technology wasn't quite ready for that when they wanted to launch the format.
"Only arskin" But does the final sampling rate matter Hugh for a read only product? So long of course it is 20kHz capable. Surely 60kHz would have reduced playing time a fair chunk?
Postby Hugh Robjohns » Sun Dec 08, 2019 5:45 pm
Martin Walker wrote:However, I rather went off them when they started releasing more expensive 24-bit digital downloads alongside the standard 16-bit versions. I simply find it difficult to believe that the vast majority of listeners would be able to hear any difference on already mastered output :headbang:
It would be interesting to do a null comparison and see what additional audio information is contained in those bottom eight bits. I'm betting on exclusively noise -- ambient room noise, electronic noise, or dither noise.... :lol:
I only read Hi-Fi News and Record Review when I'm on a train journey these days -- the hi-fi world is just too bonkers for monthly outings... but their tech reviews are still very good, and one of the regular sections is a review of the latest download releases -- most of which are 24/96 or higher sample rates. They always publish spectrograms of these downloads, and its interesting/disturbing/disappointing to see how many are either up-sampled from base rates, or have obvious technical problems in the ultrasonic region.
Thankfully, I suppose, no one can hear these problems and no one tests for them, so the record companies can get away with it most of the time... But the punters still insist the sonic value of their 192kHz nonsense... :headbang:
I've said it here before... it is highly educational to invest in a simple 'bat detector' and then go take a listen to the 30-60kHz spectrum in the recording venue. It's frightening how many 'whistles' and hoe much noisy stuff there is from LCD screens, SMPS power supplies, lighting systems, and other stuff... Thank goodness the microphones mostly roll-off above 15-20kHz... :D
Postby ef37a » Mon Dec 09, 2019 9:24 am
WRT the original question...Yes!
Just now listening to Breakfast on R3 and the link chap (Petrock?) was at a comfortable, easily understandable volume. Then came the 4th mvmnt of Tchaikovsky's 4th, the one with the big drums and loud brass. Total wimp! The drums were several dBs under the VO.
I do understand that dynamics have to be controlled for radio (actually this is Freeview through a modest 5.1 system) but come on!
Postby Hugh Robjohns » Mon Dec 09, 2019 11:10 am
I agree entirely.
Petroc's voice was peaking between PPM 4 and PPM5, and the loudest parts of Tichykowoski ;) barely reached PPM4 -- I've just played back the listen again file and viewed on my studio meters!
I found that rather surprising too... I would have expected the big bits to be banging out close to PPM6, and it was a good 8dB lower than that.
Don't know if there's a policy decision to hold things down in the breakfast programme, or if it was being mixed by someone with a hangover.... :D
I'll see what I can find out.
