Re: Will M-Audio ever support midisport in Catalina?
Tomás Mulcahy wrote:Wow, great find. Claims that they wrote the original driver. Scary Terminal stuff, but I will try it if I go to Catalina.
Edit: And I think now I actually did install the M Audio driver on my Mojave machine
The M-Audio driver will work with Mojave, as Mojave still supports 32 bit drivers, although if any other MIDI drivers are 64 bit, they are prevented from running, i.e some of the Roland drivers. The whole exercise of revamping 20 year old code to compile and run as 64 bit drivers was to be able to run on Catalina (which no longer supports 32 bit drivers), and eventually Big Sur.
There is no longer a need to run any commands in Terminal to install. Just download the .pkg file from the sourceforge.net link on the GitHub README page and double click it. I am preparing support for the non-MIDISPORT devices that use the same driver, such as the Oxygen 8 keyboard, Quattro etc. Please contact me if you have one of these boxes/keyboards as I will need some testers.
