Will M-Audio ever support midisport in Catalina?
Re: Will M-Audio ever support midisport in Catalina?
Postby poetica1985 » Mon Mar 01, 2021 9:36 am
poetica1985 wrote:
leighsmith wrote:I responded privately to your message, but for information for other readers, repeating here, I've opened an issue ticket https://github.com/leighsmith/midisport-macos/issues/18 on the project's GitHub page to add support for the Ozone.
The technical issues are outlined there, but briefly: Indeed the firmware for the Ozone is installed by the MIDISPORT installer to the disk, but there is some work necessary to have that firmware then transferred to the Ozone (it uses a different protocol, DFU, than that used by the MIDISPORTs, it seems), and there is some work to investigate which protocol such DFU devices use, either the same non-standard protocol the MIDISPORTs use, the USB MIDI class compliant spec, or some other non-standard protocol.
Thanks so much Leigh, you’ve given me a bit of hope! I will follow your advice! :)
So I’d got as far as trying to install the firmware downloader but a message came up saying this installer is not suitable for this operating system...I’m currently running Catalina
poetica1985
Postby Fredo Frito » Tue Mar 02, 2021 4:10 pm
leighsmith wrote:I've now released an open source driver https://sourceforge.net/projects/midisport-macos/files/ for the MIDISPORT boxes that run as 64 bit drivers on MacOS 10.14 (Mojave) and 10.15 (Catalina). Hope this helps folks create.
Hi, I've installed last version of the driver and it works flawlessly on Catalina. I was about to give my MidiSport 2x2 away. Thanks!!!
Fredo Frito
